what do you use ??
supra steveo
Guest mk47
t cut seems to work ok obviously on the outside..i use it and a few other people i know do too and it works a treat.although it may not be reccomended? im not too sure.
I used T-cut first then, Maguires plastex after as its finer than t-cut. The T-cut soon takes off the yellowing, and the plastex gives a crystal clear finish :)
It's not a great picture, but you can see which one of my lights have been done. I got the Maguires Plastex of e-bay by the way.
anything abrasive should do it but try it on a small patch first...
I even resorted to meguires metal polish followed by some cutting compound.
autosol would probably work too
you can feel the difference with your fingers, before = rough surface, after = smooth :)
