Bill Prawn Posted June 7, 2006 Share Posted June 7, 2006 Went to use the washer jets the other day and they didn't work. So filled the bottle and they still didn't work. On closer inspection it appears that they were disconnected during the respray. Ok methinks they will just push back on. But no they don't as I can't my fingers inside the bonnet to get at the jets. Now I'm guessing that there should be some sort of pipe from the bottom of the washer jet to the rubber tubes, is that correct? Quote Link to comment Share on other sites More sharing options...
Bill Prawn Posted June 7, 2006 Author Share Posted June 7, 2006 I know washer jets are boring, but can someone please look under their bonnet. Thanks:) Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted June 7, 2006 Share Posted June 7, 2006 there is a tube but its probably still on the original pipework. and they took off the tubes from the jet not the splitter. get abit of welding wire or similer and hook the tube out and then you can push them back on ok. also they may be blocked so use a pin down the jet holes Quote Link to comment Share on other sites More sharing options...
Bill Prawn Posted June 7, 2006 Author Share Posted June 7, 2006 No tubes at all. So another fine bit of British workmanship Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted June 7, 2006 Share Posted June 7, 2006 pop bonnet, get somone to push the water button and you look to see where water is coming from. there probably should be a pipe, so attach it to the jets....bobs your uncle and fannies your aunt Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted June 7, 2006 Share Posted June 7, 2006 No tubes at all. So another fine bit of British workmanship i've got shit loads i'll pop some in the post if you need it? and don't mind a little wait;) Quote Link to comment Share on other sites More sharing options...
