Guru Posted June 7, 2006 Share Posted June 7, 2006 Ok so I was just about to mount my boost gauge in the air vent next to the clock. So I take everything off and start to think about blocking it up first. SO as a test I block it with my hands and put the air on full to see where the air will come out of once blocked ok. After 3-4 seconds the air dies and I have no power to stereo, air con, air power or clock. I have checked a couple of obvious fuses and nothing wrong.....ideas anyone? Quote Link to comment Share on other sites More sharing options...
Daston Posted June 7, 2006 Share Posted June 7, 2006 Ha I also seem to have a simular problem I sprayed my dash put it all together and now my instrments dont work and nether dose my dimmer Quote Link to comment Share on other sites More sharing options...
Ulrik Posted June 7, 2006 Share Posted June 7, 2006 Hmm.....Didnt you disconnect the battery when removing the dash panels ? Thats rule nr 1 Quote Link to comment Share on other sites More sharing options...
Daston Posted June 7, 2006 Share Posted June 7, 2006 Oh bolox Quote Link to comment Share on other sites More sharing options...
Marco Posted June 7, 2006 Share Posted June 7, 2006 Hmm.....Didnt you disconnect the battery when removing the dash panels ? Thats rule nr 1 Only when you have airbags, right? Quote Link to comment Share on other sites More sharing options...
Daston Posted June 7, 2006 Share Posted June 7, 2006 would that be the fuses blown then? Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted June 7, 2006 Share Posted June 7, 2006 Hmm.....Didnt you disconnect the battery when removing the dash panels ? Thats rule nr 1 ive taken my dash apart without disconnecting the battery about 5 times Quote Link to comment Share on other sites More sharing options...
Lewis Posted June 7, 2006 Share Posted June 7, 2006 ive taken my dash apart without disconnecting the battery about 5 times same here Quote Link to comment Share on other sites More sharing options...
Guru Posted June 7, 2006 Author Share Posted June 7, 2006 I've done it millions of times too but never done this Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted June 7, 2006 Share Posted June 7, 2006 no help, but I've also taken my dash apart without disconnecting with no problem. And so have other people I have watched work on soops. Must be a fuse. Have you tried reconnecting everything and tested the battery. EDITED: Thanks Guru Quote Link to comment Share on other sites More sharing options...
Guru Posted June 7, 2006 Author Share Posted June 7, 2006 "tesedt the battery"? Everything is reconnected and the battery is fine as I drove her to work today.... Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted June 7, 2006 Share Posted June 7, 2006 "tesedt the battery"?. sorry. Drugs not working yet Quote Link to comment Share on other sites More sharing options...
Ulrik Posted June 7, 2006 Share Posted June 7, 2006 Yeah you disconnect the battery, so that you dont get the Airbag error.... But i always disconnect it, just in case Feels much better... Hope you guys can sort it out Quote Link to comment Share on other sites More sharing options...
Guru Posted June 8, 2006 Author Share Posted June 8, 2006 Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 9, 2006 Share Posted June 9, 2006 My moneys on a blown fuse. Quote Link to comment Share on other sites More sharing options...
Guru Posted June 9, 2006 Author Share Posted June 9, 2006 My moneys on a blown fuse. I will be checking them ALL tomorrow but please keep suggesting as I am stumped on this one..... Quote Link to comment Share on other sites More sharing options...
Daston Posted June 9, 2006 Share Posted June 9, 2006 anyone know what fuse controls the dash dimmer and instrament lights? Cant find it in the manual Quote Link to comment Share on other sites More sharing options...
Guru Posted June 11, 2006 Author Share Posted June 11, 2006 Ok the stereo was a blown fuse in the engine fuse box. The clock, heater and blower controls are still dead though. Any idea which fuse to re-check exactly? Quote Link to comment Share on other sites More sharing options...
