CJ Posted June 6, 2006 Share Posted June 6, 2006 I know that the UK and J-spec use the above injectors but don't know the following: 1. Why Toyota chose a different version for the models? 2. If there is any performance advantage to either or? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 6, 2006 Share Posted June 6, 2006 I know that the UK and J-spec use the above injectors but don't know the following: 1. Why Toyota chose a different version for the models? 2. If there is any performance advantage to either or? Hi Impedance ( saturated) are slower to react than low impedance ( peak hold) but generate less coil heat. Quote Link to comment Share on other sites More sharing options...
CJ Posted June 6, 2006 Author Share Posted June 6, 2006 Hi Impedance ( saturated) are slower to react than low impedance ( peak hold) but generate less coil heat. Thanks Terry. So, given the choice, what would you consider to be the better version? Also, I wonder why Mr. T decided to use two different systems? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 6, 2006 Share Posted June 6, 2006 Thanks Terry. So, given the choice, what would you consider to be the better version? Also, I wonder why Mr. T decided to use two different systems? It may have been availability. At the time denso may have only offered 550cc as Peak/Hold, larger cc injectors usually are peak/hold ( low impedance) Take a read through this link I just found, has all sorts of injector tech stuff on it http://www.robietherobot.com/storm/fuelinjectorguide.htm Quote Link to comment Share on other sites More sharing options...
CJ Posted June 6, 2006 Author Share Posted June 6, 2006 Much thank you's Quote Link to comment Share on other sites More sharing options...
