Driveline and steering bits
weinelm
Various bits from my garage:
    [*]Rear O/S ABS hub & carrier with good bearing - £65
    [*]Rear O/S and rear n/s hubs & carriers with duff bearings (non ABS) - £40 each
    [*]Two ABS drive shafts from TT Auto (the shorter shaft needs a new ABS ring) - £80 for the pair
    [*]Two drive shafts from NA 5 spd (non ABS) - £100 for the pair
    [*]Steering rack, with very mild N/S leak (might even be normal - apparently they all get a bit wet in the boot ends). - £100
    [*]Pair of rear lower control arms (No 2 - the larger ones) - good condition. Perfect if you want to get some new bushes done - £40 the pair
    Postage is on top of these prices. Let me know if you need any more details.
    Cheers,
    Matt
  • 3 weeks later...
  • 1 month later...
