Fuel Pressure Regulator
supna
If the fuel pressure regulator isn't working properly would this cause idle problems (ie not pushing enough fuel through hence ecu comensating the fuel air mixture)? What are the tell tale signs of it being knackered?
Ta
David
Guest Terry S
You really need to whack a gauge on. Probably easier to swap it with someones who you know works. It could cause all sorts of fuelling problems.
Dude should have a few spare from the FSE conversions, give him a shout.
HTH
