ignition timing 22 degrees at idle
absz
checked timing on the car today and its at 22 degrees vs 10 which it should be? thats with e1/te1 connected together in serial port. idles seems fine 650/680 rpm the engine seems a bit flat in lower rev range.
any ideas whats pulling the timing.
STOCK ecu unit fitted with apexi f-manage to control 650cc injectors.
hks 264/256 cams running t60-1 turbo
Is there any cure for this CW?
I'm guessing that the lower air flows that the f-manage is making the ecu see makes it advance the timing more to compensate for the lower percieved flows?
Any simple way of altering the timing map or is an E-manage ultimate the way to go?
right, checked supROs car using the same digital timing gun i have and its showing 22degrees on his car as well ? so either i have a dodgy gun or the pick up wire ( green wire on igniter pack ) is not a good reference point for No1 cylinder.
CW after market ecu might be a possibilty in the furture when i can afford one:taped:
