nickyboy Posted June 3, 2006 Share Posted June 3, 2006 Just for the record, some advice for fitting RLTC to the J-Spec VVTi. There have been a couple of threads on this, but my ABS unit was different to the ones that have been posted up before - my larger side of the unit had 22 pins as opposed to the 26 that most other people have found. Below is the picture of the ABS unit and where the wires go/which wheels they relate to. Best advice I could give is to test by plugging in a multimeter and spinning the wheels. Then, once fitted up, before you put everything back together, plug the computer in and spin each wheel again (and do the revs) to check it is registering on the RLTC software. Bit of overkill but didn't want to find out it was wrong/not registering having put everything back together! On the ECU, the wiring was as in the other posts, the main point being that the injectors are wired in sequential order (654321) rather than the order 432165 as per the published wiring diagram. Hope that helps someone in the future. To clarify the ABS wiring is: A-3 (Red) A-19 (White) B-1 B-3 Not sure what the last 2 colours were - Emin, do you remember? It was down as purple/purple on the wiring diagram if you recall.... Link to comment Share on other sites More sharing options...
Pete Posted June 3, 2006 Share Posted June 3, 2006 Mine definitely matched this one when I did it. FR+ A21-3 (red) FL+ A21-8 (white) RR+ A20-10 (blue) RL+ A20-22 (purple) Maybe difference between input/output? Link to comment Share on other sites More sharing options...
merckx Posted June 3, 2006 Share Posted June 3, 2006 Mine, same as yours Pete. ABS Connections VVTI I've checked with my multimeter and they are correct. http://img212.exs.cx/img212/674/japvvtiabs13tx.jpg http://img212.exs.cx/img212/2817/socket17bj.jpg Small Plug Pin 3 Red wire .......Front Right Wheel Pin 8 White wire......Front Left Wheel Large Plug Pin 10 Blue Wire......Rear Right Wheel Pin 22 Purple Wire....Rear Left Wheel These are on my Oct 97 VVTI, I would be surprised if they were different on your 98 car. I checked the colours on the Injectors themselves to obtain this. http://img78.exs.cx/img78/5471/98vvtiecupins7gr.jpg Link to comment Share on other sites More sharing options...
nickyboy Posted June 3, 2006 Author Share Posted June 3, 2006 Yup - that's the ECU one too. Pete - I had the photos etc and wiring diagrams you posted but mine was just a completely different unit. NB my ABS unit matched the wiring diagrams Martin (mkivstore) sent me. So there we have it - the full range of VVTi ABS and ECU wiring diagrams. Any chance of shifting this thread and pinning it? Link to comment Share on other sites More sharing options...
jevansio Posted January 31, 2010 Share Posted January 31, 2010 Whooo, somebody else with a ABS ECU that matches mine Mine isn't a VVTi & has this ECU Link to comment Share on other sites More sharing options...
Ian C Posted February 1, 2010 Share Posted February 1, 2010 The facelift non-vvti window was under 12 months and they used two different ABS systems?! Crazy. Link to comment Share on other sites More sharing options...
jevansio Posted February 1, 2010 Share Posted February 1, 2010 The facelift non-vvti window was under 12 months and they used two different ABS systems?! Crazy. Yip, I would have put money on mine being the same as yours. Link to comment Share on other sites More sharing options...
Pudsey Posted April 28, 2010 Share Posted April 28, 2010 (edited) Is there anyone that can make this a little more straight forward. I have just been trying to fit the Race Logic into my car, and none of the wires match above. Do we have an expert in our mix........... ie... Does the abs wires have to go to specfic wheels, or will any do as long as they are abs wires. The thing that is confusing me is that my ecu is the same as the one right at the top as explained by 'Nicky Boy'. I don't have any white wire he refers too, but i do have a yellow one? The other thing is that the fuel injectors no1 and no2 have the same colour signal wires red and blue? Hopefully someone will have some ideas. Oh my car is a 1998 VVT-i Tiptronic too. Edited April 28, 2010 by Pudsey ie.... (see edit history) Link to comment Share on other sites More sharing options...
merckx Posted April 29, 2010 Share Posted April 29, 2010 (edited) Does the abs wires have to go to specfic wheels, or will any do as long as they are abs wires. They can go to any wheel, you drive the car and do a 180 degree corner and the racelogic will figure out which wheels are which. (page 18 of manual) You can use a multimeter on the wires that go to the abs computer, jack the car up and spin the wheel to make sure you've identified an abs wire. (It tells you how to do this in the manual) The other thing is that the fuel injectors no1 and no2 have the same colour signal wires red and blue? Mine were Injector 1 .. red/blue..... red wire with blue band .......... 2 .. blue/red..... blue wire with red band You can test for continuity with a multimeter to make sure you've got the right injector wire, one probe on the injector wire that goes to the ecu and the other probe on the wire thaT goes to the injector itself. Edited April 29, 2010 by merckx (see edit history) Link to comment Share on other sites More sharing options...
Ian C Posted April 29, 2010 Share Posted April 29, 2010 May as well post this up here as well -Ian Link to comment Share on other sites More sharing options...
Pudsey Posted April 29, 2010 Share Posted April 29, 2010 Great stuff thanks for the advise, but I still have a wiring not displayed the 'white' one. I will just have to do things the hard way and check the sensors me thinks. Thanks for your help. Link to comment Share on other sites More sharing options...
Ian C Posted April 29, 2010 Share Posted April 29, 2010 White and yellow can be mixed up due to lighting, fading/yellowing of colours etc. I'd imagine they are one and the same wire. Link to comment Share on other sites More sharing options...
Pudsey Posted April 29, 2010 Share Posted April 29, 2010 White and yellow can be mixed up due to lighting, fading/yellowing of colours etc. I'd imagine they are one and the same wire. Ah yes I think you probably are right there. I will see how I get on as I couldn't do anymore today as it was wet here, never bring it out in the rain. Hopefully be able to get at it tomorrow. Link to comment Share on other sites More sharing options...
Ian C Posted April 29, 2010 Share Posted April 29, 2010 Let's continue discussions in the tech thread to avoid cluttering up the FAQ entry Link to comment Share on other sites More sharing options...
Jellybean Posted June 12, 2016 Share Posted June 12, 2016 What are the pins/wire colours for Non-VVTI Speed sensors? Link to comment Share on other sites More sharing options...
