Problem help needed?
jazz1
Can anyone help me basically i thought id give the supra a little start today and i filled up the tank with 30 pounds. Now the car starts fine no problems but as soon as it starts the idle drops straight down and cuts off? anyone know why?
There be your problem....should have used petrol:)
Edited to add...sorry for polluting the tech section....didnt think
i took some pics but didnt pull anything could there be some fuses missing or should they be empty like shown in the pics?
Don't worry it's normal, they're not all used. Same for the relay that's 'missing'
Have you had the battery disconnected? If you have the ECU will have been reset which would cause a lumpy idle or the engine to cut out. It will take a few miles drive for the ECU to relearn the settings, after this it should idle okay.
started my car today and it was the battery i think and also iv let the car run for 1 hour and the revs have gone up and alot of water come out of the exhaust my brother says it could be the build up of water or the map sensor but the car doesnt cut of anymore because iv let it run for ages and reved it a few times
