edd_t Posted June 2, 2006 Share Posted June 2, 2006 Has only developed in the last couple of days. When moving forward I get a squeek with each rotation of the wheel. When going slow it sounds very much like bed springs squeeking... Doesnt seem to be anything to do with the brakes, as its the same squeek with them on or off (if that makes sense) Think it could possibly be a bearing??? Anyone got any thoughts... I have quite a bit of driving to do on Monday, so would be helpfull if I were to know that I should arrange another car or something... Quote Link to comment Share on other sites More sharing options...
Guest Kazimodo Posted June 2, 2006 Share Posted June 2, 2006 hi if its not the brakes which squeeked when mine went,it could be the shockers,which was my last problem,leaking oil from one side,still drivable though at the mo.plan to have them changed this weekend kaz Quote Link to comment Share on other sites More sharing options...
D8MOA Posted June 2, 2006 Share Posted June 2, 2006 prob a bearing Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 2, 2006 Author Share Posted June 2, 2006 hi if its not the brakes which squeeked when mine went,it could be the shockers,which was my last problem,leaking oil from one side,still drivable though at the mo.plan to have them changed this weekend kaz dont think it could be the shockers as it happens with each rotation of the wheel. not when go over bumps and stuff.. prob a bearing thats what im thinking. anyone got any idea on the sort of money I may have to fork out? and if its safe for me to do about a 120 mile round trip (mostly M25 ) Quote Link to comment Share on other sites More sharing options...
supRo Posted June 2, 2006 Share Posted June 2, 2006 Edd, Possibly your handbrake shoes/springs. Try lifting the handbrake slightly when moving slowly....check if the sound differs? Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 2, 2006 Author Share Posted June 2, 2006 Edd, Possibly your handbrake shoes/springs. Try lifting the handbrake slightly when moving slowly....check if the sound differs? will do, cheers fella... Quote Link to comment Share on other sites More sharing options...
supRo Posted June 2, 2006 Share Posted June 2, 2006 will do, cheers fella... Not a definitive test though, better to remove the disc and inspect the springs/shoes and check for scorching inside the brake disc, the part that sits on the hub. Quote Link to comment Share on other sites More sharing options...
D8MOA Posted June 2, 2006 Share Posted June 2, 2006 ive got a hub with bearing if you want to borrow as you wont have time to do the bearing for monday Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 2, 2006 Author Share Posted June 2, 2006 cheers mate. but ive arrange to borrow the gf's car. will be checking the stuff out over next couple of days with dad. Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 3, 2006 Author Share Posted June 3, 2006 ok, i think it might be the hand break shoe/springs... when i started my journey the squeek had gone, till i got down the road and it started again! so i slowed to about 10, pulled the handbreak slightly and all i got was a shhhhhhhh noise. the noise disapeared after that, for a little while now its back! Quote Link to comment Share on other sites More sharing options...
Feakins Posted June 3, 2006 Share Posted June 3, 2006 Think I have this on mine too, makes more of a noise when turning right tho and its already had a new wheel bearing. Booked in the garage on Wednesday. Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 8, 2006 Author Share Posted June 8, 2006 ok took the wheel off. theres no warped disk. theres no stones. the break shoes seem to be sitting fine. but when you spin the hub, theres a little squeek! is there anything that I could oil perhaps??????? Quote Link to comment Share on other sites More sharing options...
suprattgaz Posted June 9, 2006 Share Posted June 9, 2006 Bearing, or spring popped out in horse shoe. Both have happened to me. Sounds like bearing though. Do it quick or you can damage the hub!!! Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted June 9, 2006 Share Posted June 9, 2006 is it quite a light squeaking noise? do your wheels expose your hub centres? only noticed it in hot weather driving with the windows down passing a hard obeject like a car or wall? could be the retainer and split pin on the hub - mine squeaks like a bitch some times. doubt it's a wheel bearing - they don't squeak, just a heavy grinding that gets faster as the car does. Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 9, 2006 Author Share Posted June 9, 2006 the sound got quite bad on monday, this was after about a 80 mile trip, you could hear the noise from inside the car, with the windows up! but yesterday the sound almost vanished, could hardly hear it with the windows down whilst driving past a wall! the wheel covers the hub centres. and i have only noticed it this week since the weather has been getting a lot hotter out there. we took the wheel off and turned the hub by hand, and the squeek was still there, its not a grinding noise, more of a shhhhhhh noise. Quote Link to comment Share on other sites More sharing options...
suprattgaz Posted June 9, 2006 Share Posted June 9, 2006 They do sqeek and not grind, hence why mone got bad. Didn't sound like a bearing so left it. It finally seized and rotated on the hub, and so damaged the hub aswell!!!! Quote Link to comment Share on other sites More sharing options...
s crane Posted June 9, 2006 Share Posted June 9, 2006 gbh motor sport did my wheel bearing in about 3 hour ,i think it was £140;) Quote Link to comment Share on other sites More sharing options...
Feakins Posted June 11, 2006 Share Posted June 11, 2006 Sounds exactly the same as the noise i'm getting. Phoenix are doing the bearing a week Tuesday. Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 12, 2006 Author Share Posted June 12, 2006 gbh motor sport did my wheel bearing in about 3 hour ,i think it was £140;) yeh i think im gonna have to go see GBH. problem is i have to have a day off work to do it all might aswell get the cars first service at the same time. Quote Link to comment Share on other sites More sharing options...
Amir khan Posted June 15, 2008 Share Posted June 15, 2008 Hi all, did you guys find the problem in the end? Im having the same thing on mine, Its mainly noticable below 20mph and after that goes quieter - but makes as similar noise as if you are braking. I also notice it comes and goes. Its not brake related. Any updates on this would be very helpful! Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 23, 2008 Author Share Posted June 23, 2008 update! blimey its 2 years old lol. yes in the end i had the wheel bearing changed, all was ok after that. Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted May 11, 2009 Share Posted May 11, 2009 You saved my day! Got the same problem now Would you advice to only change the bearing or more? (hub etc)? Quote Link to comment Share on other sites More sharing options...
Amir khan Posted May 11, 2009 Share Posted May 11, 2009 I think its adviced to change the hub bearing and spindel, But Id double check first Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted May 12, 2009 Share Posted May 12, 2009 An advice: I checked it again today. It is NOT the bearing or else. Its the heat shield behind the disk Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted May 13, 2009 Share Posted May 13, 2009 Just 1 more question. The heatshield at the brakes. Should i remove it or maybe replace/relocate it? Quote Link to comment Share on other sites More sharing options...
