Timwildman Posted January 10, 2004 Share Posted January 10, 2004 Not knowing a lot about gearboxes etc, Could this system be fitted to the auto box/triptronic? would it be worth it? as you will still have the same drive train losses. From my very basic driving experience the auto seems quite quick already. Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted January 10, 2004 Share Posted January 10, 2004 Originally posted by Chris Wilson IMO it's a horrible box. Positively truck like change. OK, it's strong, but a torquey turbo engine doesn't need 6 ratios, and over driven ratios aren't needed on a perforfance only car. There are much nicer changing boxes able to carry the torque. T5 is a nicer shifting box, and bits are a lot cheaper. Sorry Chris, but I disagree with you here. A 3.0l I6 is hardly a torque monster, especially with a larger turbo setup. For a car like this, the more gears the better to stay in the powerband. Also, what gearbox can take 700+ HP and still has a smooth change? Also, 6th may suit the definition of an overdrive, but topping out at below 200mph on a car that can reach that sort of speed relatively easily makes it a necesity. I class it as a very useable gear. The 6th gear in a Viper is a true overdrive, as the car can barely accelerate in it, and it is amssively longer than 5th. Quote Link to comment Share on other sites More sharing options...
Keith C Posted January 10, 2004 Share Posted January 10, 2004 Isn't the Getrag box in one of the Corvette's, as well as the R34 Skyline and Supra? Increases the chances of a conversion if it is Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted January 10, 2004 Share Posted January 10, 2004 Also in the M3 apparently............ Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted January 10, 2004 Share Posted January 10, 2004 There's a big feature on the Zeroshift system in the current edition of RaceCar Engineering. Obviously the designers are still sorting out their patents etc, but the data does look very interesting. It even makes gearboxes cheaper to make! I have to agree with CW, transmission is about to make a fundamental change. To all you drag racers out there, how does a 12.7 metre advantage on a 10 second run sound? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 10, 2004 Author Share Posted January 10, 2004 Originally posted by Timwildman Not knowing a lot about gearboxes etc, Could this system be fitted to the auto box/triptronic? would it be worth it? as you will still have the same drive train losses. From my very basic driving experience the auto seems quite quick already. No, it's for true manual boxes only. Quote Link to comment Share on other sites More sharing options...
blackshadow Posted May 2, 2008 Share Posted May 2, 2008 that link on the spec dont work can u supply a better one? Quote Link to comment Share on other sites More sharing options...
Marty Posted May 2, 2008 Share Posted May 2, 2008 hmmm... i wonder why it doesn't work.... Quote Link to comment Share on other sites More sharing options...
Pete Posted May 2, 2008 Share Posted May 2, 2008 that link on the spec dont work can u supply a better one? Well it was from over four years ago!! Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 2, 2008 Share Posted May 2, 2008 Lol, I'm reading the thread like Chris wrote it today , never noticed the date till Pete pointed it out, only 6 years to go till we find out if he was right then, I'll bookmark this thread Quote Link to comment Share on other sites More sharing options...
michael Posted May 2, 2008 Share Posted May 2, 2008 I never did get that cigar I won Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted May 2, 2008 Share Posted May 2, 2008 Did the number of 'membership expired' not give you a hint?! Quote Link to comment Share on other sites More sharing options...
Scott Posted May 2, 2008 Share Posted May 2, 2008 What happened with it anyway? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 2, 2008 Author Share Posted May 2, 2008 It seems to have died a death I have a Hamlet dog end from tonight, send me your address Michael, I don't Welsh on bets Hang on, where's this bet? Dual clutch transmissions have taken over, but they are heavy, so gear diameters and widths have been cut to a minimum, resulting in little extra torque capacity. I'll wager another cigar the new GTR will have problems, when modded, with the stock transaxle, far above the problems putting more torque through the conventional R34 Getrag box nad separate axle.. Quote Link to comment Share on other sites More sharing options...
