12V Mod on standard Jspec Pump
Supra ST Myster
Guest Terry S
I agree with Chris. I can see no reason to do the mod as the JDM cars switch to 12v as soon as positive boost is made anyway. Now if you could switch it from 9v to a constant 14v, that would make a difference..... Pete
Guest Terry S
They seem to be. It really needs someone with a fuel pressure gauge on a UK car to check. On mine ( J Spec) prior to all the work, you could visibly see on the gauge the jump as soon as the car made positive boost. I think Chris confirmed this some time back.
I have a gauge fitted and I believe that I am still 9v/12v.
I'm assuming my Walbro and FSE will not give the same result as the stock regulator?
Terry, I was told that the Walbro doesn't "like" running at 9v ??
:conf:
ALL TDi Walbros come with the 12v/12v relay kit as standard,
and give the "they-don't-like-it" reason....... ??
I thought the idea was, if you've De-Catted etc the 12v mod
allows slightly (miniscule?) better pick-up by being on-the-ball
BEFORE positive boost ???
[i DUNNO......... bleet.... bah:blink: ]
FatS.
I would say the reason to do the 12v conversion is more safety as you are relying on a box of tricks to switch you to 12v , its a mini ECU and as such i suppose could malfunction and leave you boosting like mad with a fuel pump not running at full efficiency !!
Dude:flame Dev
Guest Terry S
I think the 12v mod has come from the US. I also suspect the JDM car behave different. I will see if the walbro chart shows 9v and get back to you.
Guest Usmann A
Also, when doing the 12V mod, does the fuel pump ecu have to go?
As, Thier is no FP ecu in my dads car, and hes had the 12V mod done?
But, surely by having the fuel pump on constant when the ignition is one, there is a danger factor to take into account aswell, what if one has an accident?
U
Guest Terry S
Right the only charts I have start at 12v, so they may not like 9v. If that's the case, to me it's all the more reason to insist on a UK pump. Part #'s Denso 195130-1020 or Toyota 23221-46110
:conf:
Spoke to Walbro people today - who basically haven't taken the 341 down to 9V
'For every one volt drop you get a corresponding 20% decrease in pump effeciency'
This suggest that you should run the 12 volt mod with a relay with a walbro
BTW - we sell both - Walbro and Relay!
:thumbs:
:thumbs:
My Walbro runs fine in 9v/12v mode and you don't get to listen to the whining noise.
I thought this was whole the reason why Toyota actually did the variable voltage in the first place. When the car's not being pushed, the pump doesn't need to be flowing anywhere near as much fuel as at WOT... Hopefully increasing the life of the pump ect.
I converted back to 9v/12v to try and isolate a problem and was advised by a well known tuner to change it back to 12v asap , good enough for me , BTW the whinning noise is cool , normally the only whinning i hear is the uk owners saying they cant keep up !!!!
Dude:flame Dev
U
Thats what the relay mod is for , contact Matt H and he will sort you out and be nice to you !!!!!
Dude
