GeordieSteve Posted May 30, 2006 Share Posted May 30, 2006 Anyone know where I can get one of these from? http://www.boostlogic.com/install_manual/oil-return3.jpg The one that came in my kit is too small and it's holding up the build Link to comment Share on other sites More sharing options...
supradibbs Posted May 30, 2006 Share Posted May 30, 2006 contact greg and sam at turbofit mate and get the one from the xs power kit belive me from the experence i had with my one the xs one is far better Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 30, 2006 Author Share Posted May 30, 2006 I have the XS kit but it didn't come with a flange to fit I PM'd turbofit a few days ago but got no reply Link to comment Share on other sites More sharing options...
absz Posted May 30, 2006 Share Posted May 30, 2006 i did't get one in the kit either:( modifyed the orignal oil return hose to suit. Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 30, 2006 Author Share Posted May 30, 2006 i did't get one in the kit either:( modifyed the orignal oil return hose to suit. aha! now this is what we were thinking. Is it working ok? Link to comment Share on other sites More sharing options...
absz Posted May 30, 2006 Share Posted May 30, 2006 aha! now this is what we were thinking. Is it working ok? yep had no problems, blanked off one oil return to one branch and used the other. Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 30, 2006 Author Share Posted May 30, 2006 Fantastic stuff. Just been having a look and it looks like the job is back on. Top stuff Link to comment Share on other sites More sharing options...
absz Posted May 30, 2006 Share Posted May 30, 2006 what size turbo are you fitting? Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 30, 2006 Author Share Posted May 30, 2006 GT4088 mate Link to comment Share on other sites More sharing options...
terribleturner Posted May 30, 2006 Share Posted May 30, 2006 Steve Sam is very busy, i'll mention it to her tomorrow but your best bet is to give them a call. They took adelivery of new ones just the other day so there should be available for you Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 30, 2006 Author Share Posted May 30, 2006 Cheers mate but it sounds like I'm sorted now if I can use the stock return and hose. Contacted them about a V band clamp as well but I can wait for that for now. Don't want to push them too much if they're busy Link to comment Share on other sites More sharing options...
TLicense Posted May 30, 2006 Share Posted May 30, 2006 I don't have these in my Blitz twin kit. I was going to measure it up and get some made bespoke at work. Can anyone tell me if there are any gaskets behind these? Also if when these arrive, if anyone could post up some dimensions, like between the fixing holes, and the diameter of thread of the centre hole, that would be fantastic! Cheers guys! Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 30, 2006 Author Share Posted May 30, 2006 It has a metal gasket behind it as stock mate Link to comment Share on other sites More sharing options...
TLicense Posted May 31, 2006 Share Posted May 31, 2006 Nice one, cheers! Link to comment Share on other sites More sharing options...
Supra_Steeve Posted May 31, 2006 Share Posted May 31, 2006 Check on Ebay, I have bought it there. Link to comment Share on other sites More sharing options...
Lucifer Posted May 31, 2006 Share Posted May 31, 2006 Turbofit have them in stock. Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 31, 2006 Author Share Posted May 31, 2006 Think I'll be doing what absxxxx did and just reuse the stock unit just purely to speed things up a bit Link to comment Share on other sites More sharing options...
terribleturner Posted May 31, 2006 Share Posted May 31, 2006 Is the stock one big enough out of intrest?? I only ask as the one you would normaly get froma single kit is about 2 or 3 times bigger. Maybe ask in the tech section. Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 31, 2006 Author Share Posted May 31, 2006 I mean the flange from the oil return is what I need and use the hose from there. Looks like Keef or Wayne might have a spare anyway Link to comment Share on other sites More sharing options...
supradibbs Posted May 31, 2006 Share Posted May 31, 2006 seriously dude i would not use the stock Link to comment Share on other sites More sharing options...
absz Posted May 31, 2006 Share Posted May 31, 2006 seriously dude i would not use the stock why not:rolleyes: Link to comment Share on other sites More sharing options...
terribleturner Posted May 31, 2006 Share Posted May 31, 2006 The only problem i can see is the size but im not 100% sure that really is a problem. Plus those AN fitting ones (blue) love to leak. If you can get away using the stock one then i would Link to comment Share on other sites More sharing options...
GeordieSteve Posted May 31, 2006 Author Share Posted May 31, 2006 The only problem i can see is the size but im not 100% sure that really is a problem. Plus those AN fitting ones (blue) love to leak. If you can get away using the stock one then i would I was thinking of using the stock feed purely for the flange. I was gonna cut the pipe down to a couple of inch then use the hose from there Link to comment Share on other sites More sharing options...
Miguel Posted May 31, 2006 Share Posted May 31, 2006 Voila Link to comment Share on other sites More sharing options...
terribleturner Posted May 31, 2006 Share Posted May 31, 2006 Good job Mig tis all clear now. Link to comment Share on other sites More sharing options...
