Pixelfill Posted May 30, 2006 Share Posted May 30, 2006 Hi guys, does anyone have a user manual for the SARD R2D2. I've recently been noticing a vibration noise, coming from the turbo / bov area of the engine, when backing off boost. It seems to happen if I gently lift off at about 3500-4000 rpm. I'm hoping its related to the Bov and not a tubby, so I wondered what the adjustment nut is for. Any advice appreciated Mike Link to comment Share on other sites More sharing options...
wez_p Posted May 30, 2006 Share Posted May 30, 2006 if it's anything like the one on my Blitz BOV, it's to adjust the pressure that the valve will open at it's something like, if the screw is all the way in, it takes more force to open it & you can guess the rest is yours mounted using the location from the stock BOV or just held in place with the pipework? Link to comment Share on other sites More sharing options...
wez_p Posted May 30, 2006 Share Posted May 30, 2006 i've got a stock one at home if you want to try it out & eliminate the BOV? or you can pop my Blitz on & test it Link to comment Share on other sites More sharing options...
Pixelfill Posted May 30, 2006 Author Share Posted May 30, 2006 Cheers Wez, Mine's held in place with a bracket away from stock location, fed by 2 pipes. I might take you up on that test, I'll try changing the screw to see if it makes a difference. Mike Link to comment Share on other sites More sharing options...
wez_p Posted June 4, 2006 Share Posted June 4, 2006 any joy Mike? i quite fancy trying a Sard on mine to see if it sounds any good Link to comment Share on other sites More sharing options...
Pixelfill Posted June 4, 2006 Author Share Posted June 4, 2006 To be honest Wez, I forgot. I've found a slight cooling problem, the electric fan is on constantly when the fuse is in, so I've been trying to sort that. What's this Blackpool meet that Gill was talking about yesterday? it's suppised to be on today but don't know where or when. Mike Link to comment Share on other sites More sharing options...
wez_p Posted June 4, 2006 Share Posted June 4, 2006 know nothing about it matey, just off to have a look in the NW meets forum now... EDIT: not sure if anything is actually on, didn't see it in time Link to comment Share on other sites More sharing options...
