Ian W Posted May 30, 2006 Share Posted May 30, 2006 My girlfriend's Seat Leon 1.4S (1999) seems to be having trouble when re-starting when warm. I used to have a Toledo that wasn't great for this but it still started after the second attempt. Just wondering if you guys have experienced this before or have an idea what would cause it in a Leon? It just seems to be getting worse and when she tried to restart if this morning after stopping for five minutes it took some time to get it going. ta Quote Link to comment Share on other sites More sharing options...
Digsy Posted May 30, 2006 Share Posted May 30, 2006 Vapour lock in the fuel lines can cause this, especially if the engine is running hot, or the ambient temperature is high. Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 30, 2006 Author Share Posted May 30, 2006 Vapour lock in the fuel lines can cause this, especially if the engine is running hot, or the ambient temperature is high. cheers digsy. solution anyone? Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 30, 2006 Share Posted May 30, 2006 Next time it happens try flooring the throttle slowly and then turning the key and see if it starts easier. I have this problem on my pug and it's due to a combination of a rich mixture and a defective choke diaphram. Quote Link to comment Share on other sites More sharing options...
Ian W Posted May 30, 2006 Author Share Posted May 30, 2006 will see if that helps next time, cheers guys. Quote Link to comment Share on other sites More sharing options...
