jot_ie Posted May 29, 2006 Share Posted May 29, 2006 This speedo converter http://www.ncs-systems.com/details.php?pID=1213 Has anyone used it or know anything about it I sent them an email and this is what I got back John, Thank you for your enquiry (received both mails - still clearing a back log of enquiries). The SpeedM8 converter will work fine with your Supra. It works by converting the input signal to the speedometer to produce a MPH readout, while maintaining the output signal as original until the roadspeed exceeds aprox 105 MPH. At this point, the ouput speed frequency is locked to a constant frequency which has the effect of defeating the factory set speed limit. As soon as the road speed falls below the locked point, the output frequency returns to normal, ensuring that peripheral systems work as intended. To order a converter for your vehicle, follow the link below and enter your details via the checkout. Please contact me if I can be of further assistance. Regards Does this sound ok for a vvti 6speed? John Link to comment Share on other sites More sharing options...
Pete Posted May 29, 2006 Share Posted May 29, 2006 Interesting looking gizmo, not seen that before. The bits that are important: As soon as the road speed falls below the locked point, the output frequency returns to normal, ensuring that peripheral systems work as intended. I wonder how the peripheral systems behave above this point? What is the speed range is for the speed sensitive steering? If it's between say 30 and 90 then that should be ok. Anyone know? The programmable version of our product can be set up in seconds to suit over 250 different imported vehicle models. A programming pack is available for Trade customers. For Private customers, we can supply a converter ready programmed to suit your vehicle, complete with installation instructions. So do they have a program for a VVTi 2JZ-GTE engine? It seems so. The Trade pack looks particularly interesting. This screenshot actually lists VVTi Tip tronic - ooh I'm getting excited now. Maybe this will be the saviour of the weird SLD / TSD convertors on the VVTi autos. http://www.ncs-systems.com/speedm8/demo.php Link to comment Share on other sites More sharing options...
Pete Posted May 29, 2006 Share Posted May 29, 2006 Seems odd they have a PO Box. Domain name regged to Nottingham Car Security NOTTINGHAM CAR SECURITY LIMITED M R COWDREY & CO (Their accountants) 125 NOTTINGHAM ROAD STAPLEFORD NOTTINGHAM NOTTINGHAMSHIRE NG9 8AT Company No. 04041711 Status: Active Date of Incorporation: 27/07/2000 Country of Origin: United Kingdom Link to comment Share on other sites More sharing options...
Pete Posted May 29, 2006 Share Posted May 29, 2006 Also see this thread from the people that make it discussing such issues. Ends up pointing back to the Thor one anyway. Link to comment Share on other sites More sharing options...
ivan Posted May 29, 2006 Share Posted May 29, 2006 For those that don't know - as the car was never meant to go over 180Kph (112Mph), it wasn't programmed with a gearbox shift point over this speed (from 3rd to O/D (4th)). So when you delimit (and/or convert to Mph) the car will not change from 3rd to O/D over 180Kph (112Mph) at full throttle. You have to back off and let the car drop revs a bit before it will change.I've always wondered why it does that... Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2006 Author Share Posted May 30, 2006 For those that don't know - as the car was never meant to go over 180Kph (112Mph), it wasn't programmed with a gearbox shift point over this speed (from 3rd to O/D (4th)). So when you delimit (and/or convert to Mph) the car will not change from 3rd to O/D over 180Kph (112Mph) at full throttle. You have to back off and let the car drop revs a bit before it will change. [quote} I've always wondered why it does that... Would this matter in a manual 6 speed How is the car likely to behave above the clamped signal output At the mentioned speeds it hardly matters if the power steering doesnt contiue reacting under speed control, as long as it holds its setting Does that make sense? It does seem to be the answer for the vvti I think I might try one John Link to comment Share on other sites More sharing options...
Gaz Walker Posted May 30, 2006 Share Posted May 30, 2006 Looks like the holy grail to me. I can maybe arrange a GB if you guys want? Gaz. Link to comment Share on other sites More sharing options...
Pete Posted May 30, 2006 Share Posted May 30, 2006 Looks like the holy grail to me. I can maybe arrange a GB if you guys want? Gaz. At such little prices it's probably not worth it though? I've asked them various questions about the tip in particular - will see what the reply is. Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2006 Author Share Posted May 30, 2006 Finders Fee? John Link to comment Share on other sites More sharing options...
jot_ie Posted May 30, 2006 Author Share Posted May 30, 2006 Does anyone know if Pete from Thor ever got the one he was developing, sorted out? I would prefer tp buy one from him if possible. John Link to comment Share on other sites More sharing options...
jot_ie Posted June 6, 2006 Author Share Posted June 6, 2006 Did anyone get any more info on this, some sent emails, were there any replies? John Link to comment Share on other sites More sharing options...
Pete Posted June 6, 2006 Share Posted June 6, 2006 Did anyone get any more info on this, some sent emails, were there any replies? John Nope. Useless. Link to comment Share on other sites More sharing options...
jot_ie Posted June 6, 2006 Author Share Posted June 6, 2006 Typical There was another one I came across as well. Unfortunately I dont have a link to it. I will have to go searching I think it may have been australian (maybe) and the box was yellow Anyone ever come across something like this? John Link to comment Share on other sites More sharing options...
jot_ie Posted June 6, 2006 Author Share Posted June 6, 2006 http://www.blackrobotics.com/yb_home.htm Found it Its adjustable as well Anybody care to comment on the more technical aspects of this? Link to comment Share on other sites More sharing options...
Jake Posted June 6, 2006 Share Posted June 6, 2006 http://www.blackrobotics.com/yb_home.htm Found it Its adjustable as well Anybody care to comment on the more technical aspects of this?iirc, Tony License reckons the YELLR ones are really good. Edit: Sorry, just realised that wasn't very technical Link to comment Share on other sites More sharing options...
Pete Posted June 6, 2006 Share Posted June 6, 2006 http://www.blackrobotics.com/yb_home.htm Found it Its adjustable as well Anybody care to comment on the more technical aspects of this? It only has an input and an output though? You need an 1:1 normal signal for the g/box, steering etc. and you can't splice and share the one output IIRC? Link to comment Share on other sites More sharing options...
