RedM Posted May 27, 2006 Share Posted May 27, 2006 Is it possible, within a realistic budget, to get proper ducting done for an FMIC? Has anyone had it done or know who does it? Link to comment Share on other sites More sharing options...
Rich Posted May 27, 2006 Share Posted May 27, 2006 Is it possible, within a realistic budget, to get proper ducting done for an FMIC? Has anyone had it done or know who does it? hi martin,Eyefi has done this http://www.mkivsupra.net/vbb/showthread.php?t=45819&highlight=eyefi Link to comment Share on other sites More sharing options...
RedM Posted May 27, 2006 Author Share Posted May 27, 2006 If only he worked on Supras for a living! Link to comment Share on other sites More sharing options...
JohnA Posted May 28, 2006 Share Posted May 28, 2006 Even if you manage to duct it properly (aim for airtight at the front) you still need to duct the rear of the FMIC and couple it to the front of the condenser and the coolant rad as well. Even then you'll be redirecting extra hot air in the engine bay (the stock setup directs this hot air outside the bay, in the front wheel arch) Instead of trying to re-invent the whole wheel, why don't you try to invent just the extra bit that you feel you need over and above the stock setup? Here's an idea: Fitting a chargecooler after the SMIC will add no appreciable pressure drop and it would only have to handle the thermal 'overflow' from the SMIC under full boost conditions. The chargecooler rad could be easily placed on the passenger-side duct, avoiding any hanky-panky with the stock airflow, coolant tank or active spoiler (it is like an oil-cooler rad and so are the pipes involved). No extra heat will be dumped in the bay either, and the air/water heat exchanger can replace the stock SMIC -> TB pipe. That's what I would do if I needed extra charge-cooling on the supra. Link to comment Share on other sites More sharing options...
darren j adams Posted May 28, 2006 Share Posted May 28, 2006 I have my fmic ducted with rubber seal ,have not tested yet to see if it has dropped my temps but im sure it will. No duct between fmic and rad because its not needed ,fans pull air through rad. everything you do to reduce temps makes power,if cheap aluminium duct helps then fit it,make templates in cardboard the cut out in ali ,then rivet in place. Ive sealed the bumper to the intercoller at the bottom and cut the upper part of the mouth of the bumper and ducted in ali up to the top of the intercoller . D. Link to comment Share on other sites More sharing options...
garetheves Posted July 12, 2006 Share Posted July 12, 2006 Can i resurrect this thread and ask a reallllllllllllllllllllly dumb question please (ive had a hard day at work)?? What exactly does ducting a FMIC entail and what are the benefits of doing this?? Link to comment Share on other sites More sharing options...
Scooter Posted July 12, 2006 Share Posted July 12, 2006 As far as i understand it......... the smic's supply of air comes via the hole in the bumper. Once this air comes in it is 'forced' through the IC as there is no other route it can (easily)go. The low pressure area of the wheel arch helps with the flow too. On a front mount IC it is argued that the air, or alot of it, can flow around the sides top and bottom of the cooler, ie without ducting its not forced to flow through the IC. Intuitively i would say that ducting the area in front of FMIC to the front bumper would have the most effect on forcing the air through. benefits are a more efficient IC and therefore lower charge temps and more power......... just my thoughts...... Link to comment Share on other sites More sharing options...
Lewis Posted July 12, 2006 Share Posted July 12, 2006 what about sealing the area between the bumper and the IC, surely that would have the same effect? Could b done with some shaped rubber. Link to comment Share on other sites More sharing options...
JohnA Posted July 12, 2006 Share Posted July 12, 2006 All the ducting in the world won't do much if there is no pressure difference across the core. Example: duct it perfectly, then fit a cardboard at the back of the core. Will it flow jack? Link to comment Share on other sites More sharing options...
b_have Posted July 12, 2006 Share Posted July 12, 2006 Mine is fully ducted. Made an undertray to seal the nosecone to the fmic, then using lots of polythene and injected expanding foam, made s "stuffer plug". Link to comment Share on other sites More sharing options...
JohnA Posted July 12, 2006 Share Posted July 12, 2006 Have you ditched the aircon condenser Charlie? Link to comment Share on other sites More sharing options...
b_have Posted July 12, 2006 Share Posted July 12, 2006 Have you ditched the aircon condenser Charlie? Yes (but I'm still cool as f*ck) Link to comment Share on other sites More sharing options...
Scooter Posted July 12, 2006 Share Posted July 12, 2006 All the ducting in the world won't do much if there is no pressure difference across the core. Example: duct it perfectly, then fit a cardboard at the back of the core. Will it flow jack? there are no frequent complaints of overheating on FMIC'd cars so the flow must be ok for the ''last in the chain'' radiator. If you duct the front ie between bumper and FMIC then i think you can ensure the FMIC is working more efficiently than if you don't duct the front, no? Link to comment Share on other sites More sharing options...
JohnA Posted July 12, 2006 Share Posted July 12, 2006 ..If you duct the front ie between bumper and FMIC then i think you can ensure the FMIC is working more efficiently than if you don't duct the front, no? definately. Anything is better than the air escaping from around the core. Another way to increase the pressure difference across the core is to fit a bonnet vent a-la-Evo. This will increase the air throughput without increasing the size of the openings at the front. Link to comment Share on other sites More sharing options...
