Guest lloydmcc Posted May 27, 2006 Share Posted May 27, 2006 dose it really work Quote Link to comment Share on other sites More sharing options...
Wez Posted May 27, 2006 Share Posted May 27, 2006 50/50 mix with meths is good Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 27, 2006 Share Posted May 27, 2006 dose it really work What do you wish to achieve with it? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 27, 2006 Share Posted May 27, 2006 Water injection serves 2 closely related functions on a turbo engined car. Firstly it cools the charge air temperature by utilising an effect known as the latent heat of evaporation. This property can be self demonstrated very easily. If you pour something that evaporates quickly like petrol on your hand it feels very cold. This is the rapidly vaporising spirit removing heat from your skin and bloodstream by the aforementioned process. By spraying a very finely atomised mist of water into the inlet of a turbo engine when under boost conditions the evaporation of the water into steam causes a temperature reduction in the air and fuel intake charge. A cold charge is less likely to be subject to detonation than a hot charge. A cool charge is also denser, able to carry more air and fuel mix per unit of volume. These 2 properties of water injection allow either less chance of detonation at a given boost, maybe allowing lower octane fuel to be used, or to allow a rise in boost pressure usage without detonation. These are very desirable goals for any modifier of a turbo engine, or one using an engine mapped to run on a higher octane fuel than generally available in the UK. Japanese import turbo cars for example. People ask whether squirting water into an engine causes corrosion. In fact this is not a problem, the combustion temperatures under boost ensure the water is turned instantly to steam and is ejected out of the exhaust. The water mist is injected only when high boost is sensed via a supplied pressure sensor switch. The basic combustion process of hydrocarbon fuels causes LOTS of water to be generated anyway, which is why cars not driven on regular long journeys will rust out a mild steel exhaust system from the INSIDE out. If water is added in the correct volume, via the supplied, calibrated jets, this is not a problem. Even when used alongside a larger or more efficient intercooler, or indeed when an intercooler is used in an application where one was not present as standard, water injection can and does increase charge cooling still further. Water can be stored either in the existing windscreen washer bottle or in a separate, dedicated, container. In cold conditions it is essential to add an anti freeze additive to the water to stop pump damage through freezing. Windscreen washer additive serves this purpose fine and the engine won't mind ingesting this solution at all. Or you can add neat methanol, which is usually the anti freeze additive in washer fluid anyway. Using a 50 / 50 percent by volume water / methanol mix will actually help increase the octane of the intake charge, as an added benefit. As a yet further advantage the latent heat of evaporation of methanol is extremely high. A win / win situation. It is not however obligatory to use methanol as an additive. All components of the water injection kit that are in contact with the fluid are stainless steel or able to tolerate water and methanol or screen washer additive without degradation. A properly set up system does not use a vast amount of water, in fact a modern car sized screen washer bottle used also for the water injection reservoir will suffice admirably. A water filter is included to keep any sludge out of the pump or jet. This should be checked regularly for contamination and blown out if residue is apparent within. Quote Link to comment Share on other sites More sharing options...
Guest ldor1 Posted May 27, 2006 Share Posted May 27, 2006 [COOL][/COOL] Chris, youre the man, Had one on my Impreza and it kept the Knocklink quiet no XMAS trees lights. Dont let the pump run dry. I fitted a float switch in the tank to prevent that happening. Quote Link to comment Share on other sites More sharing options...
Guest lloydmcc Posted May 28, 2006 Share Posted May 28, 2006 thanks mate all you need to know there Quote Link to comment Share on other sites More sharing options...
supraguye Posted September 24, 2007 Share Posted September 24, 2007 Guys, I've read alot of positive reviews on water/alcohol/meth injection. A mate of mine was telling me that if too much is sprayed, it could actually blow your engine. I am not mechanically inclined, so please escuse the fact that I am unable to explain why. Is this true? He was also telling me, there are 2 types of kits, the fixed and progressive rate ones and was explaining that the progressive ones are better. Can anyone shed some light on this? Thanks Dudley Quote Link to comment Share on other sites More sharing options...
uk-rich Posted September 24, 2007 Share Posted September 24, 2007 he is talking about NOS, ignore him ! Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 I have a Coolingmist water/meth system in my Mk4 Golf Gti 1.8T. You can check intake temps with VAGcom. When the water inj kicked in the temp dropped instantly from 28degrees to 14. Its like a fmic in a bottle but with the added benefit of increasing your fuel octane. On the REVO adjuster I had the timing set at 9 (as high as it will go) which is supposed to be used only with race fuel and the ECU only backed off the timing slightly when the boost spiked at 3500rpm. Coolingmist is great value. I got the kit with the in-car variocontroller which makes setting it up a lot easier. You control what psi it kicks in at and what psi it reaches maximum flow at and also the flow rate of the pump. I think it cost me about £250. The cheapest aquamist system is mid £400s You can't do damage with too high a flow rate but you will lose power and might even feel the engine misfire. To set the system up properly on a supra you would really be better using a dyno. It was easy on the golf with vagcom giving realtime data Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 Oh by the way Chris..... I havent seen it explained better mate Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 24, 2007 Share Posted September 24, 2007 Oh by the way Chris..... I havent seen it explained better mate Even if he did get it straight from the ERL Aquamist site;) Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 Hehe whistleblower! Stealin the man's thunder Sure at least he made the effort to cut and paste it. Wherever it came from its all good. I'm a big fan of water/meth. I've lost my hair but u should see the size of my.... Club member Quote Link to comment Share on other sites More sharing options...
b_have Posted September 24, 2007 Share Posted September 24, 2007 Its like a fmic in a bottle but with the added benefit of increasing your fuel octane. Has no effect on fuel octane, but because of the dramatic charge cooling effect, it makes the engine less prone to det/pre-ignition. Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 Using a 50 / 50 percent by volume water / methanol mix will actually help increase the octane of the intake charge, as an added benefit. When using methanol as a fuel in spark ignition engines it can offer an increased thermal efficiency and increased power output compared with gasoline due to its high octane rating and high heat of vaporisation. It's low energy content of 19.7 MJ/kg and stoichiometric air fuel ratio of 6.42:1 do however mean that fuel consumption (on volume or mass basis) will be high. Why else do dragsters use methanol? Quote Link to comment Share on other sites More sharing options...
robert_gray Posted September 24, 2007 Share Posted September 24, 2007 Iv'e been thinking about this for some time and was wondering what system to get. Are the coolingmist systems that much better than the aquamist? Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 I don't know about better. Most of the systems on the market use a sureflow pump. The coolingmist controller gives great control. You can even plug a laptop into it and alter the way the mix is delivered using their free software. It was mainly the price that affected my decision but it helped that a friend of mine was using coolingmist with good results too. Have a look at their site . I would recommend adding the filter and block detector to the kit. http://www.coolingmist.com/ Quote Link to comment Share on other sites More sharing options...
lui Posted September 24, 2007 Share Posted September 24, 2007 All positive comments on water injection so far Can't wait now as im having the latest Aquamist kit in pic below fitted to my car this Wednesday It's the new HFS-5 Water Injection System by Aquamist. Will be fitted by Mark@Phoenix wiring by Matt Harwood & mapped by Ian C http://img504.imageshack.us/img504/4511/hfs5mcw2.jpg http://img504.imageshack.us/img504/4511/hfs5mcw2.b1cd43ec93.jpg Quote Link to comment Share on other sites More sharing options...
supraguye Posted September 24, 2007 Share Posted September 24, 2007 I don't think any of us really doubt its effectiveness. My question was really that if sprayed in excess, could it cause damage to your engine? I was actually thinking of buying one of the non progressive coolingmist kits:(http://www.coolingmist.com/pagedisplay.aspx?feature_key=standard). It apparently comes with a boost sensitive switch and you have to let them know how much horsepower you currently have so they can provide the correct jet size Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 wooo! looks tasty! Do you have a methanol supplier? I get mine from a lab supplier. Its as pure as you can get. Costs me £18 for 5ltrs though. It is a lot cheaper from a regular chemical supplier but the ones in my area only sell 50gallon drums! Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 I don't think any of us really doubt its effectiveness. My question was really that if sprayed in excess, could it cause damage to your engine? I was actually thinking of buying one of the non progressive coolingmist kits:(http://www.coolingmist.com/pagedisplay.aspx?feature_key=standard). It apparently comes with a boost sensitive switch and you have to let them know how much horsepower you currently have so they can provide the correct jet size No it definitely wont damage your engine. The most it will do is drown the combustion process making the engine misfire and stall. The basic kit is a lot cheaper but it delivers the mix at one speed. The vari-control is well worth having as it starts pumping at a low rate and rises as the boost rises. You will eventually save the extra cost of buying it as it uses less meth than the basic kit. Quote Link to comment Share on other sites More sharing options...
supraguye Posted September 24, 2007 Share Posted September 24, 2007 No it definitely wont damage your engine. The most it will do is drown the combustion process making the engine misfire and stall. The basic kit is a lot cheaper but it delivers the mix at one speed. The vari-control is well worth having as it starts pumping at a low rate and rises as the boost rises. You will eventually save the extra cost of buying it as it uses less meth than the basic kit. Just the response I was looking for Dave. Now I can justify shelling out for the vari-cool kit. Thanks! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 24, 2007 Share Posted September 24, 2007 Boost triggered WI is OK for a charge cooling or det suppression, don't know why they would calculate jet size by BHP? using to big a jet in the scenario would lose you some power, and can cause bog down, to get the best out of WI the Aquamist 2C and the new HFS-5 that lui is using is a much better bet, as this uses the HSV which to all intense is a fuel injector for water and so can be controlled and mapped by a suitable ECU, far better than the pressure triggered systems, as you then have precise control throughout the RPM and load range, and with the added benefits of the DDS3 and V8 etc you then have the added fail safes of map switching and boost cut should you run out of water or other related problem. Quote Link to comment Share on other sites More sharing options...
lui Posted September 24, 2007 Share Posted September 24, 2007 The new HFS-5 that lui is using is a much better bet, as this uses the HSV which to all intense is a fuel injector for water and so can be controlled and mapped by a suitable ECU, far better than the pressure triggered systems, as you then have precise control throughout the RPM and load range, and with the added benefits of the DDS3 and V8 etc you then have the added fail safes of map switching and boost cut should you run out of water or other related problem. Cheers Dick mate could'nt of described my system that i have in short terms any better Quote Link to comment Share on other sites More sharing options...
Guest DaveWilko Posted September 24, 2007 Share Posted September 24, 2007 I have no doubt you are correct but what price is it? With the current exchange rate the yankee kit is great value for those of us on a budget. Also as a very rough way of setting it up, if the engine bogs down, even with the most basic system you adjust the pump pressure so it doesn't bog down Quote Link to comment Share on other sites More sharing options...
lui Posted September 24, 2007 Share Posted September 24, 2007 I have no doubt you are correct but what price is it? I think they will be retailing at a tad under £600 not cheap From Aquamist UK Quote Link to comment Share on other sites More sharing options...
