Guest jj-jap Posted December 26, 2003 Share Posted December 26, 2003 Hi every one...i am new to this forum...and i am need of some assistance...i have recently bought a jap spec NA manual ...and..i have not had much of a chance to drive it lately,but i have noticed that the gearbox is showing signs of wear? .......as i have not owned a supra before i was hoping you lot could help as to if its in need of a rebuild ...if so where to get a box,or fit a second hand one..and how much....1st 2nd and 3rd,make a groaning noise 4th and 5th are fine...its not too loud but loud enough?....the rest of the car is in very good nick....it has covered 54,000 miles.......bit early for a box to go?...but maybe you lot can help....thanks Link to comment Share on other sites More sharing options...
toyotasuprauk Posted December 26, 2003 Share Posted December 26, 2003 Hi and welcome to the site. Needing a gearbox rebuild with such low miles doesn't sound normal. Have you checked/toped up the gearbox fluid level or changed it? That's what I'd do first. Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 26, 2003 Share Posted December 26, 2003 Thanks for the reply........i have had a quick look underneath..no leaks that i can see......do you know what oil to use ....i think i will try this first as you say...as the milage is too low...for a nacked box...... Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 26, 2003 Share Posted December 26, 2003 It is very unusual for these boxes to give trouble at any mileage. let alone low mileages. The oil level needs checking, just looking for oil drops is not enough. If the oil level is correct it may be a mainshaft bearing gone. Manual gearbox parts are VERY expensive, a good used box will be cheaper than a proper repair. I am only near Whitchurch and have extensive Supra MKIV experience, if you want me to have a look at it or check the levels for you just e-mail me direct, see my sig below. Good luck. Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 27, 2003 Share Posted December 27, 2003 Thanks chris.....i maywell call in on you.....so that i can check the oil level ...whats the best oil to put in........also...whats a good box cost these days... Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 28, 2003 Share Posted December 28, 2003 well i changed the oil today,and well its still the same..but changes gear easier when cold....and this may be a bit weird but when the gearbox is cold,its making a whining noise in the first 3 gears...but as the box warms up the noise almost dissapears?...odd or what........ Link to comment Share on other sites More sharing options...
blackmax Posted December 28, 2003 Share Posted December 28, 2003 I've not got alot of knowledge in this matter but... could it not be the Thrust bearing in the clutch..?? It's most definately coming from the box.. not a wheel bearing...???. Sorry just trying to keep an optimistic view the thought of you having to get a new gearbox scares the crap out of even me..! Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 28, 2003 Share Posted December 28, 2003 funny you should say that?....but i was thinking that....as there is a bit of a release bearing noise...that goes when the pedal is pressed.... ...next question....as i am new to supras...is this a mega job?cost wise aswell... Link to comment Share on other sites More sharing options...
dude Posted December 28, 2003 Share Posted December 28, 2003 Just because you press the clutch and the noise goes doesnt mean that its the release bearing , i would let CW have a look , he will tell you what you need to budget for !!! dude:flame Dev Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 28, 2003 Share Posted December 28, 2003 think i will give him a shout... Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 28, 2003 Share Posted December 28, 2003 In neytral, 1500 or so revs. Clutch pedal depressed, noise goes away = almost certainly gearbox bearing(s). Noise stays or gets worse usually = release bearing knackered. Sounds like the box has a *uggered bearing(s) in it. A proper box rebuild will cost a lot more than a used box. i would expect to pay about 200 or so for a guaranteed quiet and perfect synchro used box. I don't know of any for sale though, sorry. Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 28, 2003 Share Posted December 28, 2003 cheers chris ...u have mail Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 28, 2003 Share Posted December 28, 2003 Been out side and run the car noise goes....think i have just wasted £30 on gearbox oil... Link to comment Share on other sites More sharing options...
Supra_Al Posted December 30, 2003 Share Posted December 30, 2003 .............i seem to remember that a Mk3 Supra Turbo, uses the same gearbox(manual) as an import N/A Supra?? If this is the case, you can buy one very cheaply indeed!!?? Al. Link to comment Share on other sites More sharing options...
Guest jj-jap Posted December 30, 2003 Share Posted December 30, 2003 Can anyone confirm this?....if this is the case i will be looking for one asap.... Link to comment Share on other sites More sharing options...
Supra_Al Posted December 30, 2003 Share Posted December 30, 2003 I'm sure someone will be along to answer this for you,in the mean time if i can find the article,i'll post it up for you.Al. Link to comment Share on other sites More sharing options...
