pistonbroke Posted May 25, 2006 Share Posted May 25, 2006 I've been toying with the idea of putting a front mounted intercooler on my soop, thing is, its still running standard tune with only a HKS dump valve and HKS exhaust. The main reason for the FMIC is for looks, it changes the look of the front of the car nicely IMHO. What I'm asking is, will I cause any problems for the car if I was to fit one.? And, will it affect performance in any way? Quote Link to comment Share on other sites More sharing options...
Alex Posted May 25, 2006 Share Posted May 25, 2006 All will be fine unless your Radiator is already half dead...in which case fitting an FMIC infront of it will highlight that your rad is failing. But that's not the FMIC's fault... Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 25, 2006 Author Share Posted May 25, 2006 Aww crap, and mines an auto, so the rads not cheap because of its liitle gearbox cooling brother that needs to be purchased as well. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 25, 2006 Share Posted May 25, 2006 If it's just for looks then take a picture of one and blow it up, laminate it and stick it behind your bumper. Much cheaper! Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 25, 2006 Author Share Posted May 25, 2006 Well, Pete, I suppose thats slightly better than your Mech Warrior link laser suggestion I've just read on another thread. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 25, 2006 Share Posted May 25, 2006 Well, Pete, I suppose thats slightly better than your Mech Warrior link laser suggestion I've just read on another thread. Can't say I'm not inventive [edit] I've just re-read it. I really do talk bollocks sometimes don't I? Quote Link to comment Share on other sites More sharing options...
heckler Posted May 25, 2006 Share Posted May 25, 2006 Aww crap, and mines an auto, so the rads not cheap because of its liitle gearbox cooling brother that needs to be purchased as well. erm.. the cooler is built into the rad... cos i have an auto rad on my TT6 - Unless you have an aftermarket rad... Quote Link to comment Share on other sites More sharing options...
Alex Posted May 25, 2006 Share Posted May 25, 2006 erm.. the cooler is built into the rad... cos i have an auto rad on my TT6 - Unless you have an aftermarket rad... Indeed a stock TT Auto rad is about £400 from Toyota. And the cooler for the box is INSIDE the radiator. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 25, 2006 Author Share Posted May 25, 2006 I thought it was more than that, thats why MKIVStore is supplying fluidyne rads for apparently less than mr t ones, but they need the seperate autobox cooler. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 25, 2006 Share Posted May 25, 2006 I thought it was more than that, thats why MKIVStore is supplying fluidyne rads for apparently less than mr t ones, but they need the seperate autobox cooler. Because aftermarket parts are usually cheaper than OEM and Fluidine don't want to manufacture two different cores so adapt one for autos. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 25, 2006 Share Posted May 25, 2006 I've been toying with the idea of putting a front mounted intercooler on my soop, thing is, its still running standard tune with only a HKS dump valve and HKS exhaust. The main reason for the FMIC is for looks, it changes the look of the front of the car nicely IMHO. What I'm asking is, will I cause any problems for the car if I was to fit one.? And, will it affect performance in any way? Dont do it unless you need it Get some decent mesh (I sell some and fit it across the front if looks are what you are after All IMHO of course Quote Link to comment Share on other sites More sharing options...
Alex Posted May 25, 2006 Share Posted May 25, 2006 Dont do it unless you need it Get some decent mesh (I sell some and fit it across the front if looks are what you are after All IMHO of course Yeah 'cause mesh looks like an FMIC... Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 25, 2006 Share Posted May 25, 2006 Yawn....I rest my case (without the temp no plate of course) Quote Link to comment Share on other sites More sharing options...
