Boost Gauge Vs S-AFC readings?
randy
I have a Greddy 60mm boost gauge reading off the vacuum line and I have my Apex- S-AFC reading the turbo pressure off the computer. There is a difference in the reading when the gauge shows 1.2bar boost. The S-AFC shows only 1bar? Can someone explain why there is a difference in the readings?:)
You need to be measuring manifold inlet pressure, not say pre-intercooler or at the turbos for instance.
At the end of the day the Toyota or Apexi or whatever MAP sensor should read the same as your mechanical boost gauge if it's any good. As 1 bar is 1 bar no matter where you are.
It's all based upon sea level anyway.
The answer you are looking for is here........
I would however note that electronic gauges are only accurate within there specified range of operation. (much like a mechanical needle gauge is only good for the range as show on the dial face)
SO as the Stock Toyota MAP sensor ONLY goes up to a max of around 18.5psi it starts to get a little flakey and inaccurate, out of range. So while the mechanical dial gauge is good for 1.2 bar the AFC which uses the MAP sensor reading from the stock MAP sensor then it's at it's limit of operation and thus cannot be trusted to be accurate.
This is why you can never fool the ECU into injecting more fuel at WOT with just an AFC (or similar) as it's limited partly by the inaccurate (or out of range) MAP sensor.
So I bet at 1.0 bar they both probably read the same.
However ...they "should" both read O.K. up to the limit of the stock MAP sensor which is about 1.2 bar but I guess in your case the MAP sensor is poor ********OR********* the setting on your AFC or set up incorrectly.
Ahhh! Could be the AFC is plumbed in after the Fuel Cut controller or something and it's this that is clamping the max output of the MAP sensor to 1.0 bar ??
The AFC should be loom side and FCD (VFCC) ECU side.
regards
Pete
