Rear hubs removal
Digsy
Gearing up to swap my rear hubs over next week. I had a read of the workshop manual last night and was rather surprised about how much you seem to have to take off to get the hubs off. I was kind of hoping that I could just disconnect the ball joints at the hub carrier end, undo the Jesus nut in the middle, remove the caliper and tap the thingy off the driveshaft - job done. Troube is, the manual says you have to drop trhe exhaust, remove the complete driveshaft from the diff end and take a load of the suspension joints off the car.
Is that all true, or is there a simpler way?
i didnt remove the exhaust or the driveshafts. i basically did it how you said by just unbolting tie rods and ball joints from the hub end. i think i may have had to completely remove one tie bar but cant really remember to be honest
Terrif. I hoped someone would say that :) I think the reason Toymota suggest taking the driveshaft out is that their SST ball joint splitter is the size of a pregnant whale and wouldn't fit in otherwise.
MAy I ask what kind of splitter you used? THere are actually two SSTs for the job but I don't fancy forking out for either. Do Halfrauds or Wilco do one that would fit?
When i took them off i just tapped the side of the hub where the joints sit. Dropped out lovely. Ball joint splitters just fcuk the rubber seal. :)
same as that. i did have a splitter but it wasnt big enough for one of the ball joints
Yeah - the fork type ones mess up the seal, but you need two different sizes of non-contact type splitters (bad design - well done Toyota ;) )
Hopefully a tap will do the trick.
