FMIC? Are you sure???
TLicense
OK guys I've had enough.
Time and time again I read "oh you're going single. You're going to need a FMIC"
I'm not so sure.
The whole point of getting a larger turbo, is that for a given pressure the turbo is working more efficiently. This directly relates to the air coming out of the turbo, being cooler.
So why oh why is the general consensus "You NEED a FMIC?" when the fact of the matter IMHO is you need a FMIC less than what you would need to get the same pressure out of a stock turbo.
I've just bought a reasonably large turbo kit. Will I be fitting a FMIC? Will I hell. My SMIC has worked fine with the "off the efficiency island" stock turbo's running at 18 - 20 psi, so I'm pretty sure it will work just as fine with air that is cooler to start with. OK the SMIC on my car has seen better days, and will in fact be getting upgraded to a new one, and yes a FMIC will reduce the inlet temps further and give more power, but in my opinion it's not neccessary
Thought's guys?
  • Replies 146
Guest Flat4_ire
I'm not so sure.
Thought's guys?
ok no its not completely neccessary but if u want the most and safely power from your upgraded turbo kit a nice siz fmic is the way to go, allows u to run higher boost safely and keep charge temps down, all preference at the end of the day, but why cut corners for the sake of a few quid?
Why's it cutting corners? If I can run 1.2 bar on my stock turbo's with no det, how would running a cooler 1.2 bar on a aftermarket turbo/s be more dangerous?
By that rational, we should all have WI as well and NOS. Safety first and all that!
I do not think the SMIC will be efficient enough to cool the amount of air that you will be putting into it with a reasonably large turbo. If it was that easy to skip the FMIC install with a larger turbo wouldn't more people be doing it ?
There must be a reason for that. ;)
I do not think you can just say 1.2 bar on one turbo should be the same on all turbos. Case in point. I ran my old HKS GT3040 at 1.5 bar many times without any issues. That turbo was rated for up to 500hp. I upgraded to a GT40-67 turbo that was rated for 700hp and the one time I upped the boost to 1.5bar I blew a piston and had a major engine fire that wrote off the car.
How is 20psi of boost from a single more air than 20psi of boost from the stock peashooters?
Seach button :p As I swear I went through this with you ages ago in detail on another thread:)
Simply put bigger fans move more air at the same pressures. Thats why as Gamer has mentioned a 61 , 71, 76, 88 will all put out more power respectively at the same boost. An engine simply is an air pump, the more air you feed it the more fuel you can add to it and the more power you release.
I'm sure we had this one a good few months ago.. you, me, and migster explaining it all. Volume is different to pressure, or something :) It's like how it's easy to create 20psi of pressure when you're trying to force it through a mac donalds straw, but blowing that same air into a drainpipe you have no pressure at all. Or something :)
Good memory that man :)
As a rule-thumb, every 5oc drop in charge temperature results in an air density increase that allows for a 1% increase in gross power output. Likewise, an 5oc increase in charge temperature can reduce power output by about one percent.
Guest gzaerojon
am i right in thinking the colder the air the more volume you can pump into the engine in the same area of pipe?
for example if you put an inflated baloon in liquid nitrogen it will shrink, but then when it warms up it inflates again, the volume of air doesn't change, it just becomes more compact and need less area to exist.
so in theory you could get more air into the engine if its colder?
feel free to shoot me down :D
No need to shoot you down. You are flying high at the moment, live it up mate.
