hks turbo timer type 1 rpm output!
supra matt
if you go to hks europe you can down load the manual for the timer.
you have to set the unit up to your car. rpm and speed.. on rpm rev car to 2k then press the set botton on the right hand side 2k will flash then when your at 2k on your cars rev counter press again. this will set your rpm. to do speed you do the same but at 40mph on your speedo then reset speed on timer.it will flash 40mph and when you are doing 40mph on the cars speedo press reset
