supra matt Posted May 21, 2006 Share Posted May 21, 2006 hi all has any one fitted one with the speed and rpm wire connected? as i just done mine and the rpm read wrong! has any one eles had this problem? Link to comment Share on other sites More sharing options...
gledo1970 Posted May 21, 2006 Share Posted May 21, 2006 if you go to hks europe you can down load the manual for the timer. you have to set the unit up to your car. rpm and speed.. on rpm rev car to 2k then press the set botton on the right hand side 2k will flash then when your at 2k on your cars rev counter press again. this will set your rpm. to do speed you do the same but at 40mph on your speedo then reset speed on timer.it will flash 40mph and when you are doing 40mph on the cars speedo press reset Link to comment Share on other sites More sharing options...
supra matt Posted May 21, 2006 Author Share Posted May 21, 2006 thanks alot mate thats great help i would go try in now but its tipping it down! Link to comment Share on other sites More sharing options...
