Whitesupraboy2 Posted May 21, 2006 Share Posted May 21, 2006 ok i ve had a weird problem of my battery light coming on,cat overheating light coming on and fluid light coming on with of course the triangle. Now when i pull away with no revs, in other words jumpy pull away the light jumps on and off. Sometimes it will come on when driving sometimes it wont. I've worked out it is a dodgy earth...i just need to find it, below are clues if someone can point me to where this dodgy earth may be, please help * when braking the light comes on, take foot off brake it goes off, put it back on it will go on. * When lights are on sidelights or dipped, i dont get none of the above lights come on at all! never. thanks James Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 21, 2006 Author Share Posted May 21, 2006 Quote Link to comment Share on other sites More sharing options...
Steve W Posted May 21, 2006 Share Posted May 21, 2006 Obvious question, but, didn't start just after changing any bulb did it ?? Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 21, 2006 Author Share Posted May 21, 2006 no, it kinda started after i changed my spark plugs....when i say started, i mean the lights started to take longer to go out when starting up. I have had the headlights completely out recently but it was doing it before and after i removed them Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 21, 2006 Share Posted May 21, 2006 Loose earth connection ? Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 21, 2006 Author Share Posted May 21, 2006 Loose earth connection ? I worked that out mate ...keep up im just trying to work out where it may be any idea? Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 21, 2006 Share Posted May 21, 2006 Story of my life mate I take it the battery terminal is on securely as well ? Have you tried the electrical manual on mkiv.com for the earth points ? HERE Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 21, 2006 Author Share Posted May 21, 2006 Story of my life mate I take it the battery terminal is on securely as well ? Have you tried the electrical manual on mkiv.com for the earth points ? HERE yeh battery is fine, if battery earth came off i presume id lose most electronics, though i will check tomorrow Now this is where i become slow ... i need a diagram that rather then electrical diagrams....shows exactly where i will find the earth on the car Also someone telling me which one is most likely there must be loads of earth points on a car like this Quote Link to comment Share on other sites More sharing options...
Lucifer Posted May 21, 2006 Share Posted May 21, 2006 It would be work making sure the ECU loom is in properly. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 21, 2006 Author Share Posted May 21, 2006 you talkin in the footwell mate? sorry this is where i become thick! Quote Link to comment Share on other sites More sharing options...
Lucifer Posted May 21, 2006 Share Posted May 21, 2006 Yes, thats where I would start, After of course checking my error codes. Quote Link to comment Share on other sites More sharing options...
Lee P Posted May 22, 2006 Share Posted May 22, 2006 Check all your earth points, you may have to run some new ones, I had a problem on my car but mine lost all power. The earthing on jap cars is shite, my battery is mounted in the boot and I had to run a new earth down the car from battery to the front of the chassis and one from the engine to the chassis just to get it started. Thanks Lee Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 22, 2006 Share Posted May 22, 2006 There is two earthing ponts on either side just in front of the door... if you have a look in the two foot wells on the pilar just below the dash, you will see two sets of white wires bolted to the chassis... Will type a longer description when I get back from seeing what is left of my license.... Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 22, 2006 Author Share Posted May 22, 2006 Thanks to you all for replies, i may invest in a grounding kit, Gav any more instructions on earthing points be great. Ill have to do this when its stopped raining. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 22, 2006 Share Posted May 22, 2006 5 points later, and still on the road... give me a call later this evening chap.. and lets see what we can do.. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 22, 2006 Author Share Posted May 22, 2006 cheers mate, will do! Quote Link to comment Share on other sites More sharing options...
