HKS SSQ D/V Fitting
SkyJawa
Ah - see what you mean now - I suppose you could also pad out the pipe to "thingy" with some electrical tape too to make the seal.
I'll have a play ;)
Managed to get 2 metres of Vacuum hose too from Camberley Auto Factors so in business there as well :) Top bunch of chaps actually, heartily recommend em at the Guildford branch :)
I don't know what difference it makes, but mine is installed vaguely where the green circle is on the picture below.
Is there any kind of benefit having it where the red arrows are instead of the green circle? (how's THAT for a technical explaination?!)
http://www.web-axis.net/~pulse/suprapipe.jpg
Had a go, theres no way that pipe is going on :eek:
Its about the right size, but the silicon piping on it is too small for the bits on the car it needs to go on to - it 6cm wide and doesn't stretch much.
So. I guess I need some new piping. Can you get samco hoses that are about 6cm, widening out to enough to go on the intercooler pipe and the throttle body?
You can have 2 valves - normally one push type and one pull type (or something!) So you have say a blitz and an HKS, you won't get 2 dumps but both going off together. Only really for high power though I think, but its pointless to leave the OEM one in and run that with the HKS...........
