SkyJawa Posted December 17, 2003 Share Posted December 17, 2003 Right, this arrived today......... (cheers Michel Guess I shouldda asked you about fitting! ) Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 17, 2003 Author Share Posted December 17, 2003 Grrrrrrr - proxy playing up. Ok - arrived: Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 17, 2003 Author Share Posted December 17, 2003 I assume I just replace this pipe to the new one with the DV fitted to it (what do I do with the OEM D/V?): Quote Link to comment Share on other sites More sharing options...
oxygene Posted December 17, 2003 Share Posted December 17, 2003 mine one didnt have the extra pipe...it straight replaced the factory one.... Quote Link to comment Share on other sites More sharing options...
Paul Laing Posted December 17, 2003 Share Posted December 17, 2003 Dunno what that pipe is, the one i have which is a xmas present replaces the stock bov. Can't you just take it off the pipe or is it welded on? Paul Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted December 17, 2003 Share Posted December 17, 2003 dont you just take off the pipe in the pic, replace it with your new one and then just either leave the standard one in, or you can block off all 3 pipes.. Just as a matter of interest can you have one hks bov where the stock one goes and also this hks bov that replaces the origanal pipe, what would happen?? Would you set one at a different pressure setting? Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted December 17, 2003 Share Posted December 17, 2003 P.S where did you buy that from as i would like one that replaces that pipe to?? Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 17, 2003 Author Share Posted December 17, 2003 I bought Michel's (on here) 2nd hand one, thats how it came, I've seen them like that before too!! I thought that was the pipe it replaced , but its mainly what to do with the OEM as I've heard you can have a DV on each side in both locations, but don't know if that counts for the stock one too and what the benefits are etc. Or what to do if you wanna remove the stock one! Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 17, 2003 Author Share Posted December 17, 2003 Eg: And where do you plumb the small hose on the DV into? Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted December 17, 2003 Share Posted December 17, 2003 the small hose can go to the origanal one and T it and leave the stock one in, or remove the stock one, join the small hose where the stock one went and block off the 2 bigger hoses, or i think there is another location on that side of the pipe work with the HKS bov that you can take it to, not sure where but belive dude has it going to it?? Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 17, 2003 Author Share Posted December 17, 2003 Ta. Yep - think I'll remove the old one and cap the pipes. So anyone got pics of where they have the little one attached to or is it simply run from over by the stock location? Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 17, 2003 Author Share Posted December 17, 2003 Pic attached of general location of smallish pipe on the throttle body I can T into...... Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 18, 2003 Author Share Posted December 18, 2003 Update with pics from manifold to check I have the right pipe! The one circled? Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 18, 2003 Author Share Posted December 18, 2003 And it goes down to like a disc thing that 2 other pipes also go into in this circle!: Quote Link to comment Share on other sites More sharing options...
Dragonball Posted December 20, 2003 Share Posted December 20, 2003 Originally posted by supra TT myster P.S where did you buy that from as i would like one that replaces that pipe to?? We can get them done for you - inc full polished pipes etc Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted December 21, 2003 Share Posted December 21, 2003 hi Paul. Yeah can you pm me a price for one of these with a hks flange on it if possible. thanks Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 21, 2003 Author Share Posted December 21, 2003 What can you use to block of the pipes from the original DV? Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted December 21, 2003 Share Posted December 21, 2003 You can get from b & q those rubber ends that goes on the bottom of chair legs, they do different sizes and they work a treat on mine with a Oclamp for the 2 pipes that you will want to block off. And for the smaller pipe attatch a bit of rubber pipeing to it and put a long screw into the end, large enough to screw it in so it stays there. Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 21, 2003 Author Share Posted December 21, 2003 Cool - have to pop to B&Q tomoz Cheers! Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 22, 2003 Author Share Posted December 22, 2003 Had a look and couldn't really find anything suitable to shove in there Quote Link to comment Share on other sites More sharing options...
Rob_B Posted December 22, 2003 Share Posted December 22, 2003 Your finger ? Have you got it working yet mate ? What does it sound like ? I have one on order atm from Envy.. Hope its loud :D Rgds, Rob. Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 22, 2003 Author Share Posted December 22, 2003 No mate, like I said, I can't find anything to bung the 2 bigger pipes on the OEM one with. Also not sure how the pipe is gonna fit the throttle body, doesn't look big enough! Hopefully Michel will shed some light on it when he gets my email Quote Link to comment Share on other sites More sharing options...
Rob_B Posted December 22, 2003 Share Posted December 22, 2003 Hi Mate.. Can't you just run it with the stock bov still in place ? I think other people run theirs like this. ? Mind you though, if you did I imagine that you wouldn't get as louder whoosh, so maybe its a bad idea :D Rgds, Rob. Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted December 22, 2003 Author Share Posted December 22, 2003 The consensus seemed to be it defeated the object of the HKS...... Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted December 22, 2003 Share Posted December 22, 2003 The rubber bits i was on about doesnt go into the pipes, its like a sleeve that fits over the pipe and then you fit a clamp that does up tighter as you screw it, and that will make sure no air escapes, i have used it on mine and works fine, they are normally near the screws section... Quote Link to comment Share on other sites More sharing options...
