darren j adams Posted May 20, 2006 Share Posted May 20, 2006 Mine are 14.5-8 on tickover! full throttle it goes off the scale rich and gauge finshes at 11. My fuel pressure is 30 at the mo static so cant reduce anymore to try and lean it. Suppose a tweek on my map is coming!! Gauge is a wonderful thing!! D. Link to comment Share on other sites More sharing options...
darren j adams Posted May 21, 2006 Author Share Posted May 21, 2006 What no one has readings?? D. Link to comment Share on other sites More sharing options...
jason m Posted May 21, 2006 Share Posted May 21, 2006 I think Jake posted a thread on this. Link to comment Share on other sites More sharing options...
darren j adams Posted May 21, 2006 Author Share Posted May 21, 2006 Do you have a link. Just wanted to see if im the only one that goes pig rich at wot. Not much good talking to yourself. Still i suppose im the only one with the gauge. D. Link to comment Share on other sites More sharing options...
LeeT Posted May 21, 2006 Share Posted May 21, 2006 mines the same on tickover and anywhere below 3.5k. at wot ive set mine up at 11.2/3 ish. i havent been mapped properly yet though Link to comment Share on other sites More sharing options...
bromy Posted May 21, 2006 Share Posted May 21, 2006 Think Jake upped the boost slightly because he was rich at WOT Link to comment Share on other sites More sharing options...
pump gas pete Posted May 22, 2006 Share Posted May 22, 2006 Esteemed Sibling Rival..... Wots the matter ? are they ignoring you? Still never mind think of the future.....its BLACK Link to comment Share on other sites More sharing options...
Lee P Posted May 22, 2006 Share Posted May 22, 2006 11 is fine at wide open throttle you are a bit rich on tickover. When your throttle is 3/4 open you want to see 13 or lower really to be safe. Thanks Lee Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 22, 2006 Share Posted May 22, 2006 Darren, my car idles at 13.6 ( seems much smoother than stoich) dropping to 11.5 at full boost. What I have noticed is that the AEM reads approx. 0.2 leaner than both my HKS Knock Monitor and my Autonic AFR analyser, but it's a consistant 0.2 so it is a great bit of kit for the money. Link to comment Share on other sites More sharing options...
jason m Posted May 22, 2006 Share Posted May 22, 2006 Do you have a link. Just wanted to see if im the only one that goes pig rich at wot. Not much good talking to yourself. Still i suppose im the only one with the gauge. D. http://www.mkivsupra.net/vbb/showthread.php?t=67001&highlight=aem Link to comment Share on other sites More sharing options...
Guest Usmann A Posted May 22, 2006 Share Posted May 22, 2006 Del, yours is ok, just a bit rich at top end like you were saying, you need stop spitting them friggin fireballs out the exhaust. I think its alot more todo with Boost, Rpm, and ign eventhough TPS can go hand in hand with RPm, but not always.(yes racecars use Alpha -N, TPS systems ) Small throttle, high rpm, cruising around 15.5-17.5afr, even more sometimes, depends on how good it resists Det, and how advanced your timing is. Cant wait for controller, then you can see exactly what shes doing, and make it faster ..... :D Link to comment Share on other sites More sharing options...
Ian C Posted May 22, 2006 Share Posted May 22, 2006 What I have noticed is that the AEM reads approx. 0.2 leaner than both my HKS Knock Monitor and my Autonic AFR analyser, but it's a consistant 0.2 Not just me that's noticed that then, good Bizarrely, the gauge actually reads 0.2 leaner than the voltage it spits out down the 5v line -Ian Link to comment Share on other sites More sharing options...
bromy Posted May 22, 2006 Share Posted May 22, 2006 Not just me that's noticed that then, good Bizarrely, the gauge actually reads 0.2 leaner than the voltage it spits out down the 5v line -Ian Well in that case cant they be calibrated, I thought they had a calibration screw on them with tamper proof/tell tale glue Link to comment Share on other sites More sharing options...
Ian C Posted May 22, 2006 Share Posted May 22, 2006 Doesn't bother me enough to find out -Ian Link to comment Share on other sites More sharing options...
darren j adams Posted May 22, 2006 Author Share Posted May 22, 2006 Thanks for link! Thanks for your help i thought everyone was ignoring me! Im only running 14 psi so maybe ill up it to 20 to see if i can lean it off. Still on 14psi i stayed next to a TL1000 bike in first and second and backed off in third so he didnt hit the island. D. Link to comment Share on other sites More sharing options...
