whats your aem uego gauge readings??
darren j adams
Guest Terry S
Darren, my car idles at 13.6 ( seems much smoother than stoich) dropping to 11.5 at full boost. What I have noticed is that the AEM reads approx. 0.2 leaner than both my HKS Knock Monitor and my Autonic AFR analyser, but it's a consistant 0.2 so it is a great bit of kit for the money.
Guest Usmann A
Del, yours is ok, just a bit rich at top end like you were saying, you need stop spitting them friggin fireballs out the exhaust. :D
I think its alot more todo with Boost, Rpm, and ign eventhough TPS can go hand in hand with RPm, but not always.(yes racecars use Alpha -N, TPS systems ;))
Small throttle, high rpm, cruising around 15.5-17.5afr, even more sometimes, depends on how good it resists Det, and how advanced your timing is.
Cant wait for controller, then you can see exactly what shes doing, and make it faster ..... :D :D :D
Not just me that's noticed that then, good :)
Bizarrely, the gauge actually reads 0.2 leaner than the voltage it spits out down the 5v line :blink:
-Ian
-Ian
Well in that case cant they be calibrated, I thought they had a calibration screw on them with tamper proof/tell tale glue
Thanks for link!
Thanks for your help i thought everyone was ignoring me!
Im only running 14 psi so maybe ill up it to 20 to see if i can lean it off.
Still on 14psi i stayed next to a TL1000 bike in first and second and backed off in third so he didnt hit the island.
D.
