Is my car BPU or LESS ?
Supe
Hi , I have a j-spec TT, manual. It has the following mods:
HKS mushroom filter
5" unknown exhaust with cats still in
HKS boost guage
stock turbos
I prefer 10w/50 silkolene fully synthetic , but I have been told
5w/40.
does it really make any difference if I stick with 10w50 as its thicker ? :cool:
For BPU
Remove both cats
Cooler spark plugs
Walbro fuel pump
Fit fuel cut defender
Fit restrictor ring to keep boost below 1.2 bar
The noise is fanastic in enclosed spaces with high buildings on each side. :D
10w50 is fine, 5w/40 might be better for a cold winter but we don't get them very often.
HKS mushroom filter
HKS boost guage
stock turbos
5w/40.
stick the stock air filter back on - unless you're silly high horsepower its proven to be better than after market air filters.
5" seems massive ! are you sure this is the diameter of the actual pipe and not just the end bit after the back box ?
so by the sounds of it the only performance upgrade is a back box which does sod all to increase power.
as Merckx says gets those cats off, up the boost (sensibly) fit the other stuff and then enjoy 350 - 400 fwhp !
