oil and front head light
wewsupra
hi ive been ill for a few days ,so i asked my friend to get me some oil and a light
she has come back with semi synthetic 10w -40{is that right}
and the light is wrong its a h4 12v{but its fat}
are import lights different to uk spek
See this thread for oil recommendations:
http://www.mkivsupra.net/vbb/showthread.php?t=56684
Which bulb are you trying to replace and which headlights do you have? If you have J-spec headlights you can't get the correct spec bulbs in the UK, but can adapt the 9005 bulb to fit.
J-spec Headlights (early and facelift)
High Beam = 9005J (use 9005/HB3)
Dip Beam = 9006J (use 9005/HB3, you will need to trim the rib on the wring loom plug to get them to fit.
Fog Light = H3
you fool :D
that oil will be fine mate as that's what Toyota actually tell you to put in the damn thing anyway. if you check around it is recommended that you use a fully synthetic but the one she got you won't do it any harm.
