Which Auto fluid to use ?
matt
Personally Matt, I wouldn't mess around with it. I will always replace my gearbox fluid with the fluid my local Toyota part dept recommend.
Manual Gearboxes can get screwed up by using other types.
But some one on this list recently recommended the Esso stuff....
Guest Martin F
Quote: from Alex Holdroyd on 8:24 pm on Nov. 18, 2001[br]Its their own purpose made oil...sorry I don't know who by...
V-160 / V-161 oil is their name for it.
Just call them up with your chassis/frame no. ready and they'll sort you out.
Alex, Matt is after fluid for an Auto box.
Toyota upgraded the Auto-box lubrication spec. in accordance with the following revision notice:
Automatic Transmission Fluids
TRANSMISSION & CLUTCH
TC003-99
Title:
AUTOMATIC TRANSMISSION FLUIDS
Models:
All Models
May 21, 1999
REVISION NOTICE:
The information contained in this TSB updates TC003-98 dated June 19, 1998.
Introduction
Automatic Transmission Fluid Type T-IV now replaces Type T-II fluid. Use Type T-IV for all applications that specify ATF Type T-II.
Please refer to the following table for the interchangeability between each ATF.
Affected Vehicles
^ All vehicles produced after 1993 with Automatic Transmissions specified to use ATF Type T, T-II and T-IV.
NOTICE: With the exception of mixing ATF Type T with Type T-IV fluids, different types of fluids must not be mixed.
Parts Information
SIZE     NEW PART NUMBER     PART NAME
4 Liter  08886-01705         ATF Type T-IV
