addi Posted December 14, 2003 Share Posted December 14, 2003 i currently run on my jspec a greddy profec electronic boost controler, it alloows me to set the pressure to run but at the moment even when lowered to 1.1 bar its stil running up to 1.3 when i nail i (very worrying) .. does this mean i need to reset it ??? any ideas pls??? (the unit came on the car when imprted and has been previoulty running fine but i have had a exhaust change since....do i need to reset the contrloler wenever i mod??? any help appreciated cheers Link to comment Share on other sites More sharing options...
cashpoint Posted December 15, 2003 Share Posted December 15, 2003 With the Greddy if you do aything to the engine that may effect the boost you need to reset the controller and as an exhaust change affects the boost you will need to get the controller reset so it learns the way the car boost now as the exhaust will reduce backpressure. Do you want to swop boost controllers as mine refuses to go above 1.1 bar and i want 1.4:mad: Link to comment Share on other sites More sharing options...
