Failed MOT on emissions
moistfinger
i would have hazarded a guess at an O2 sensor but i wouldn't have thought a 97 car would have trouble with that (although it's still nine years old i suppose). am sure someone will be along to actually help you out soon enough mate :D
Moist, the lambda sensor is on the exhaust downpipe, before the first cat. 20mm spanner required to turn it & get it out. Has 4 leads.
It must've changed on the later cars, mine had two 8mm or 10mm nuts to undo. :)
Thanks for your help Guys,
Got a new Lambda sensor fitted today and it sailed through the MOT.
Gave Steve Manley a call and he located the part I needed. Brilliant service, well recommended.:thanks:
Well done Rich.
You ok mate, hows things :)
