Optimax + Millers and an ECU reset.
Andrew
I have gone back to Optimax and for some reason I has helped with my Fuel cut off problem, strange as I thought it would be the other way round :)
Anyway I was going to use Millers to get the RON upto and around 100, but I have one question.
If I add Millers will I have to stick with it? Or can I put it in now and again?
These reason I ask is in case I cannot get hold of the stuff.
Also I understand I need to reset my ECU, So when I pull out the fuse does the ignition need to be on?
Many thanks
Andrew
1) Depends on boost pressure.
Optimax alone should be good for boost up to fuel-cut. Beyond that it's up to you. I, personally, no longer recommend boosting beyond fuel-cut without considering other factors such as additional fueling.
2) My reply in (1) refers.
3) Remove fuse with IGN off.
Yours,
J
