dandan Posted December 10, 2003 Share Posted December 10, 2003 Hi Guys, Just wondered if anyone could help me out with the following list of parts. I'd like to know anyone's ideas on availability and pricing from new and how to go about getting hold of them (ie only through Toyota???). Some of the smaller stuff (s.motor, alternator etc is available thru dealer so any part no.'s would be great). -Complete 2JZGTE engine (non vvti) (excluding: Exh manifold and turbochargers) -V160/161 6 Speed gearbox -Flywheel and clutch assembly -Intake runners and plenum chamber -Throttle assembly -Differential housing and LSD -Starter motor -Solenoid -Alternator -Fuel rail and injectors (550cc minimum, Toyota or otherwise) -Coilpacks There are a few more items in this list but I don't want to put too many or people simply won't reply. Anyone know if complete engine assemblies can be sourced direct from Japan with/without turbos, manifold and ancillaries? Any input greatly appreciated. Thanks Dan Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted December 10, 2003 Share Posted December 10, 2003 Best bet is from USA where the bits are cheaper... you looking at the cost of a supra for those parts below! Gaz. Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted December 11, 2003 Share Posted December 11, 2003 A full crated engine (oiled up and ready to go) has a list price of about £9k and a short engine (block, crank, rods and pistons assembled, UK and J spec are the same) is I think about £2.5K. This is list price so you may be able to negotiate. The alternator (at least two different ones) is about £400 ISTR. All from Toyota. Quote Link to comment Share on other sites More sharing options...
Nick Posted December 11, 2003 Share Posted December 11, 2003 I expect Chris Wilson will have/be able to source some if not all the parts. He was talking about keeping a built motor in stock a little while ago... Quote Link to comment Share on other sites More sharing options...
