andrew7 Posted May 11, 2006 Share Posted May 11, 2006 Hi guys, Recently noticed a petrol smell when stationary in traffic... Pulled up in a country lane today and lifted the bonnet, slight smell in there. Can't see any leaks or wetness on any of the pipe unions etc.. Had the O2 sensor changed a couple of weeks ago, so am wondering if it is that..or a lose plug or something else?..... Anyone had this before, it's a bit worrying with two red-hot turbos also in there............. Quote Link to comment Share on other sites More sharing options...
Jake Posted May 11, 2006 Share Posted May 11, 2006 Checked the charcoal canister? Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted May 11, 2006 Share Posted May 11, 2006 I take it this is on your Supra? (Just asking because you've posted it in non-supra technical, bit of a tumbleweed section this!). edit: sods law I post that and Jake answers Quote Link to comment Share on other sites More sharing options...
Jake Posted May 11, 2006 Share Posted May 11, 2006 I presumed it was a Supra he was on about, even though it's in 'Non-Supra Technical', because he mentioned the two turbos Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted May 11, 2006 Share Posted May 11, 2006 Yup I figured as much from the two turbos bit. Just pointing out that he'll probably have more meaningful replies in the proper technical section than in here. Ah screw it I can't help him anyway Have you checked the charcoal canister? Quote Link to comment Share on other sites More sharing options...
Jake Posted May 11, 2006 Share Posted May 11, 2006 Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 12, 2006 Author Share Posted May 12, 2006 Checked the charcoal canister? What do you check?.....or , how do you check it?... BTW the car is a Soarer (1JZ GTE)..so not much difference.. Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 12, 2006 Author Share Posted May 12, 2006 Bump Quote Link to comment Share on other sites More sharing options...
Lucifer Posted May 12, 2006 Share Posted May 12, 2006 Top right hand part of your engine bay Andrew. But I suspect it may have something to do with the New O2 Sensor no? Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 12, 2006 Author Share Posted May 12, 2006 Thinking the same Mart. Tried to call you today, busy busy....Never had the problem before it was changed and I don't exactly believe in coincidences. Changed the plugs today, but made no difference... Am soaking the old O2 sensor (which looked OK yes?) in lemon juice tonight and will change it back tomorrow, weather permitting. Got to get it right, I have to go to Heathrow first thing Monday morning... Re the Charcoal Canister, what do you check exactly?..... Oh BTW Mart, Phil seems very pleased with his new wheels... happy bunny... Quote Link to comment Share on other sites More sharing options...
Lucifer Posted May 13, 2006 Share Posted May 13, 2006 Ahhh good, lovely wheels for the money. Old O2 looked OKay... not gonna say anything about buying genuine parts Whats your MPG's like? Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 13, 2006 Author Share Posted May 13, 2006 MPG has been fine and generally car has been running fine. I am thinking that new O2 sensor is not working properly at lower revs (cos it's shorter than OEM), if that makes any sense? (volume of gases in the center of the pipe compared to volume at the edges).... Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 13, 2006 Share Posted May 13, 2006 I used to get this on my old one years ago - took out the inner plastic part in the petrol cap (the one that means you can only use smaller petrol hoses) and it worked Just my 2p worth Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 13, 2006 Author Share Posted May 13, 2006 Ahhh good, lovely wheels for the money. Old O2 looked OKay... not gonna say anything about buying genuine parts Whats your MPG's like? Changed back to the old O2 sensor this morning. No smells yet, but it is not as hot as it's been the last couple of days. Did notice on the sensor I took out that there has been blow-by between the sensor and the gasket.... Time will tell.... Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 13, 2006 Author Share Posted May 13, 2006 Got the car well hot today and didn't smell petrol once... Quote Link to comment Share on other sites More sharing options...
Lucifer Posted May 14, 2006 Share Posted May 14, 2006 Yes, I wasnt really happy with that gasket anyway IIRC. So then, a trip the the Lexus dealer? Quote Link to comment Share on other sites More sharing options...
andrew7 Posted May 14, 2006 Author Share Posted May 14, 2006 New gasket you mean?... Toyota World is where I usually get my spares...they are generally OK.. Quote Link to comment Share on other sites More sharing options...
