GavinL Posted November 19, 2001 Share Posted November 19, 2001 Hi... Has anyone removed the rear badges on a Supra before? I was thinking about getting the Toyota badge removed (I'm told that using dental floss works well) but I am concerned about any problems with the exposed paintwork (metallic silver) thanks as always................. Link to comment Share on other sites More sharing options...
Guest Martin F Posted November 19, 2001 Share Posted November 19, 2001 Gavin, Did this on ours when i put the gold badges on, and to be honest the old badges did not leave a lot behind. I used a flat plastic blade to remove the old badges and then some abrasive cleaning polish (a Turtle Wax one i think) to clean up the paintwork. Was a bit easier than i expected, particularly when you think our car is black. Martin Link to comment Share on other sites More sharing options...
Guest Ash Posted November 19, 2001 Share Posted November 19, 2001 When you say "remove" do you mean entirely, or remove and replace with some other badge? Reason I ask is because the stock badge has 3 lugs that fit into corresponding holes in the rear door. Yours, J Link to comment Share on other sites More sharing options...
GavinL Posted November 19, 2001 Author Share Posted November 19, 2001 Quote: from Ash on 12:27 pm on Nov. 19, 2001[br] When you say "remove" do you mean entirely, or remove and replace with some other badge? Reason I ask is because the stock badge has 3 lugs that fit into corresponding holes in the rear door. Yours, J Ooops, what I mean't to say was remove completely the Toyota name not Toyota badge/symbol. It looks like the letters are individually stuck on. regards............ Link to comment Share on other sites More sharing options...
Guest Martin F Posted November 19, 2001 Share Posted November 19, 2001 Yep your right, the letters of the 'Toyota' name are stuck on individually. Link to comment Share on other sites More sharing options...
mrpug106 Posted November 20, 2001 Share Posted November 20, 2001 A good way to do this is too get a hairdryer warm up the sticky part of the badges...and slowly pull off.....any residue left white spirit will get off followed by a dose of wax..! (20mins max to de-badge the rear of a supra Toyota badge and supra badge.) Link to comment Share on other sites More sharing options...
Flipfinger Posted November 21, 2001 Share Posted November 21, 2001 Hmm........looks like a cheap and potentially good fun modification.... People don't seem to know what mine is anyway, so adding to the air of mystery might help (although Gran Turismo put a bit more knowledge around). Link to comment Share on other sites More sharing options...
