Cleaning up my rear
GavinL
Hi...
Has anyone removed the rear badges on a Supra before?
I was thinking about getting the Toyota badge removed (I'm told that using dental floss works well) but I am concerned about any problems with the exposed paintwork (metallic silver)
thanks as always.................
Guest Martin F
Gavin,
Did this on ours when i put the gold badges on, and to be honest the old badges did not leave a lot behind.
I used a flat plastic blade to remove the old badges and then some abrasive cleaning polish (a Turtle Wax one i think) to clean up the paintwork.
Was a bit easier than i expected, particularly when you think our car is black.
Martin
When you say "remove" do you mean entirely, or remove and replace with some other badge? Reason I ask is because the stock badge has 3 lugs that fit into corresponding holes in the rear door.
Yours,
J
Yours,
J
Ooops, what I mean't to say was remove completely the Toyota name not Toyota badge/symbol. It looks like the letters are individually stuck on.
regards............
