Gah - Toyota! UK Owner Help Please - Brake Related!
SkyJawa
Been down to Toyota to order up the UK Spec brakes.
I went in with the list of:
UK Left Front Calliper 47750-14270 £195.19 excluding VAT
UK Right Front Calliper 47730-14260 £195.19 excluding VAT
UK Shim kit front 04945-14110 £12.43 excluding VAT
UK Fitting kit front 04947-14010 £12.25 excluding VAT
UK Left Front Disk 43516-14030 £74.03 excluding VAT
UK Right Front Disk 43512-14200 £77.07 excluding VAT
But they have said the disk part numbers are wrong, it should be one or the other as the disks are the same on both sides.
They said to call back with a chassis no. if UK or model type and chassis no if JSpec (but if JSpec they could only supply whats meant for the car). Obviously this is a UK brake upgrade so I need to quote a UK chassis no. to phone them back with so they can get me the right parts.
I'd be very grateful if the owner of one of those wonderful ;) (crawl crawl) UK cars could PM me their chassis no. :D
Thanks!
What do you mean mate - that those part no's are right, and there is a seperate no. for each side?
As they were adamant about it down at Octogon it was wrong, it would be the same part no. x2. (BTW it was both Steve and the small Irish guy I was talking too ;))
I guess I can't really go far wrong if I quote a chassis no. for a UK and ask for front left and right.........
livvy,
Superb - thanks - thats good enough for me :D
I phoned them back, and told them that others had ordered these parts and they were correct and stamped differently R and L:
43516-14030
43512-14200
So he has ordered them on the proviso if they are wrong I can't return them.
Cheers for the help :)
Should be here by friday!! :eek:
Part numbers are:
UK Spec Supra brake part nos.
Left Rear Disk 42431-14150
Right Rear Disk 42431-14150
Left Rear Caliper 47750-14280
Right Rear Caliper 47730-14270
Left Front Caliper 47750-14270
Right Front caliper 47730-14260
Shim kit rear 04946-14030
Fitting kit rear 04948-14010
Left & Right discs are different and labelled L & R and bizarely are slightly different prices.
Try another Toyota dealer - Motorline in Canterbury will get you any parts that are available.
PS (edit)
I have done this mod (front only) and bought these parts quoting these part numbers.
