Dash Rendar Posted May 8, 2006 Share Posted May 8, 2006 Ever since I went BPU a few months back (which included having the head taken apart and cleaned, FMIC, FSE, etc.), I have a funny problem starting the car when warm. It starts up really lumpy (sometimes it just cuts out) and seems to take 2 or 3 minutes to clear itself and run smooth again. During this time, if I try to put my foot down, it will start to boost but doesn't get any power... It's like it's not getting fuel or something. It doesn't happen with a cold start. Runs perfectly. Any ideas? It's not really much of a problem, but it bugs me a little and I'm wondering if I might be doing any damage. Link to comment Share on other sites More sharing options...
markssupra Posted May 8, 2006 Share Posted May 8, 2006 This sounds familiar. Trying to sort this problem myself. Link to comment Share on other sites More sharing options...
terribleturner Posted May 8, 2006 Share Posted May 8, 2006 I wonder if it has something to do with the idle air intake hose? or even the idle control valve motor?? http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13939&d=1112558977 Link to comment Share on other sites More sharing options...
Ian C Posted May 9, 2006 Share Posted May 9, 2006 What's your FSE's pressure set at...? -Ian Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 9, 2006 Share Posted May 9, 2006 FSE..... Put the stock one back and see if it creates a magical cure! Link to comment Share on other sites More sharing options...
Ian C Posted May 9, 2006 Share Posted May 9, 2006 Hoi, don't steal my thunder I was working my way up to that suggestion! First I was expecting a "I don't know, it was fitted out the box" and then I'd say and diagnose an overfuelling issue because it's at 60psi static pressure -Ian Link to comment Share on other sites More sharing options...
Dash Rendar Posted May 9, 2006 Author Share Posted May 9, 2006 First I was expecting a "I don't know, it was fitted out the box" and then I'd say and diagnose an overfuelling issue because it's at 60psi static pressure Well, this was true when it came out of the garage. With Homer's help, I found that it was actually 66psi. Anyway, the static pressure is currently 36psi. I would put on the stock fuel regulator, but I don't have one. (The garage that did the work kept my stock regulator, and for reasons I don't want to get into, I'm not bothering to try and get it back.) Anyone got one I could try, and are they easy to fit? Link to comment Share on other sites More sharing options...
Alex Posted May 9, 2006 Share Posted May 9, 2006 Well, this was true when it came out of the garage. With Homer's help, I found that it was actually 66psi. Anyway, the static pressure is currently 36psi. I would put on the stock fuel regulator, but I don't have one. (The garage that did the work kept my stock regulator, and for reasons I don't want to get into, I'm not bothering to try and get it back.) Anyone got one I could try, and are they easy to fit? The Supra's stock static pressure is 42psi. Link to comment Share on other sites More sharing options...
Dash Rendar Posted May 9, 2006 Author Share Posted May 9, 2006 Okay then, I'll notch it up a bit. Link to comment Share on other sites More sharing options...
Dash Rendar Posted September 20, 2006 Author Share Posted September 20, 2006 Apologies for resurrecting this old thread. I thought I'd update you with what happened... First, I upped the pressure from 37 to 44 psi. This mostly cured the problem. The car ran a lot less lumpy and no longer cut out when warm-started. However, the throttle response still seemed a bit random and a bit poor. It was almost as if the fuel wasn't making it to the rail. Anyway, this weekend I got rid of the FSE and had the Aeromotive FPR installed. The car now runs like a dream... Much smoother and much more responsive. So yes... You were all correct: the FSE was rubbish! Link to comment Share on other sites More sharing options...
Class One Posted September 20, 2006 Share Posted September 20, 2006 And welcome back.Your absense has been noted. Back of the class! Link to comment Share on other sites More sharing options...
SimonB Posted September 20, 2006 Share Posted September 20, 2006 The Supra's stock static pressure is 42psi. No it isn't. It's 36psi. Well actually the tech manual says 33-40psi. Link to comment Share on other sites More sharing options...
Dash Rendar Posted September 20, 2006 Author Share Posted September 20, 2006 I have been quietly posting here and there! Meanwhile, it appears you've been slowing taking over the world! How's your 'stock' motor? P.S. I forgot to mention: thanks to Phoenix for sorting out the FPR, plus a load of other minor things that needed some attention. Link to comment Share on other sites More sharing options...
terribleturner Posted September 20, 2006 Share Posted September 20, 2006 Doug's 'stock' Motor now has a Warlbro pump Link to comment Share on other sites More sharing options...
Ian C Posted September 21, 2006 Share Posted September 21, 2006 So yes... You were all correct: the FSE was rubbish! -Ian Link to comment Share on other sites More sharing options...
