supraleon Posted October 29, 2015 Share Posted October 29, 2015 As a new member this is brilliant information which is now printed off and gonna be in full use. Really helpful. Thank you Link to comment Share on other sites More sharing options...
Loonyboyo Posted November 22, 2015 Share Posted November 22, 2015 printed and read..thank's for taking the time to do the pointers Link to comment Share on other sites More sharing options...
lemonslice Posted January 8, 2016 Share Posted January 8, 2016 This will be a great help while looking for my first supra in a few months cheers guys Link to comment Share on other sites More sharing options...
Izzy Posted June 3, 2016 Share Posted June 3, 2016 Very usefull guide for me too Link to comment Share on other sites More sharing options...
Sheefa Posted September 30, 2017 Share Posted September 30, 2017 I couldn't see it in the guide when I had a flick through earlier, but definitely check the Fuel and brake lines over for corrosion. Ideally remove the plastic protecting strip under the chassis of car and see if any of the lines are corroded. Also check the power steering lines for leaks/weeping as these are getting old now, particularly just behind the rubber hosed bits which often crack. Suspension arms for any unnecessary excess play if you can jack up corners or have access to a ramp. Check all pulleys for excess movement too, might be worth doing the tippex check on crank pulley if time allows. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted October 1, 2017 Share Posted October 1, 2017 Read this year's ago, great guide for sure with a lot of helpful info. Although seen as some of these cars are are now getting on for 25 year old I do think the guide is a little over critical! A lot of the guide is common sense stuff you would check on any car! Things like where it says about smoke on start up, these are old cars now lol, i dont drive mine much, trying to keeping the mileage down as it got about 112,000miles now. If i start my car up after a couple weeks mine smokes blue from cold, clears quickly . any old car will puff a bit, when I was using my car regular like every day it don't puff at all really. Main thing is I'd say is check for smoke from turbo. Link to comment Share on other sites More sharing options...
Mike2JZ Posted October 1, 2017 Share Posted October 1, 2017 I see loads of Supra's that have issues with their warning light clusters not working fully or not at all. When you turn the key from ACC to ON, you should see all the warning lights appear on your light cluster. If any of the warning lights are missing then it could be a fault in the circuit, or someone has removed the bulb. If someone has removed the bulb for the engine warning light or master warning light for instance, then that would be an instant point to discuss. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted October 1, 2017 Share Posted October 1, 2017 If it's the top right cluster you speak off then they suffer from dry solder joints and is a very easy fix Link to comment Share on other sites More sharing options...
blue34 Posted November 12, 2019 Share Posted November 12, 2019 Thanks for the info! Link to comment Share on other sites More sharing options...
Scooter Posted November 14, 2019 Share Posted November 14, 2019 Quality lurking! 7 years between first and second posts Hope you are in a position to get one finally if you need any further specific help pop up a thread in general or somewhere else it'll be noticed. Link to comment Share on other sites More sharing options...
