aero top
Guest martin169
Ours leaks and i DO do the back bolts FIRST ! ! !
BUT, it leaks MUCH less if i spray all the rubber seals with rubber 'lube'
(oooooh errrrrrr ;) )
Halfords do a Window/Seal Spray about £4 and it doesn't take much to spray
it.
I suppose the Smear-of-Grease is same thing ???
It only leaks at the 4 corners where the window/body/aero meet and the
fit isn't 100% (how COULD it be ! ! !)
All in all, it only leaks if it's raining quite HARD and only if it hasn't been
sprayed for a while.
FatS.
Guest Kazimodo
also anyone know is the rear suspention just a bolt off bolt on ,or are any special tools needed.
lol
kazx
Get this every time it rains. I should imagine nic (import pimp) may be able to get these new.
Missed this thread before.
Thanks Jez, yes if anyone wants new seals then I can supply these. If there are enough members wanting them, perhaps I should organise a group buy, just let me know :ok:
mine has been leaking abit recently, cant you pull the roof apart and do up the front 2 screws so it pulls the roof down abit more i am sure something can be adjusted, just waiting for some nice weather i.e. the not a cloud in site sort then i might be brave and pull it apart
I would be interested in a group buy :)
You need to do the back bolts first to bring the fronts into line. Also only put the roof back on on a flat surface, as body flex can make the holes misalign.
Lastly get some silicone spray from Halfords, it’s used to bring rubber seals back to life and is very effective at stopping leaks.
