chriseltham Posted December 8, 2003 Share Posted December 8, 2003 When you fit an aftermarket front bumper what happens to the active spoiler, should it be removed, will it still function ok? sorry if this is a stupid question, just thinking outloud Quote Link to comment Share on other sites More sharing options...
far Posted December 8, 2003 Share Posted December 8, 2003 9 out of ten times it needs to be removed and will not function - taking it off is a piece of cake - after you take off the bumper you will have 4 bolts which you need to take off and unplug the motor - the active spoiler is attached to the front undertray ( not the main undertray but the smaller "nose" undertray) Quote Link to comment Share on other sites More sharing options...
Supragal Posted December 8, 2003 Share Posted December 8, 2003 Yup, unbolts from the chassis rail- apparently you need to unplug the ECU (as in the active spoiler ECU) which is behind the stereo... not got that far yet...else you'll get warning lights. Theres a fair few threads on here about it- have a search. Quote Link to comment Share on other sites More sharing options...
far Posted December 8, 2003 Share Posted December 8, 2003 the only warning lights I get is the active spoiler little green light,not sure what would be quicker removing the ecu or just reming the bulb behind the bottom of the dash Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted December 8, 2003 Share Posted December 8, 2003 An easier soloution, would be to connect the yellow and the purple/yellow wire together when you disconnect the motor, then simply turn the spoiler off Quote Link to comment Share on other sites More sharing options...
far Posted December 8, 2003 Share Posted December 8, 2003 Dam Harwood ! I had mine off on the weekend - why didnt you tell me then ? BTW - still need to catch up with you to discuss Ice install I want you to do for me Quote Link to comment Share on other sites More sharing options...
