Conrad Posted May 7, 2006 Author Share Posted May 7, 2006 1st thing i'de do is take out the restrictor ring (is it a CJ) have you changed both the cats ?, if yes the car should be flying in comparison to what it was, i'de also go bigger on the spark gap as well go for the NGKs about £14 a set Ring from Chris Wilson and both cats removed. Which NGK's do you recommend? Link to comment Share on other sites More sharing options...
hadyn Posted May 7, 2006 Share Posted May 7, 2006 Dont take out the restrictor ring out. Keep your current set up and you'll hit 1 bar eventually and about 1.1 bar when it gets cold Thats all you'll need for low 13s mate Link to comment Share on other sites More sharing options...
paul mac Posted May 7, 2006 Share Posted May 7, 2006 plugs i used at BPU were NGK BKR7E-11, i appreciate what Hadyn said in the last post but in the warm weather i would hit 1.18 (nearly 1.2) and about 1.25 bar in the winter this was with a calibrated gauge, if alls well you should be seeing way more than 0.9 and feel a big big difference Link to comment Share on other sites More sharing options...
Conrad Posted May 7, 2006 Author Share Posted May 7, 2006 Dont take out the restrictor ring out. Keep your current set up and you'll hit 1 bar eventually and about 1.1 bar when it gets cold Thats all you'll need for low 13s mate Nooooo! Must have more power! I wont rest until I'm making 1.2bar. My Sup has to be quicker than my best mates Scooby! Link to comment Share on other sites More sharing options...
hadyn Posted May 7, 2006 Share Posted May 7, 2006 Nooooo! Must have more power! I wont rest until I'm making 1.2bar. My Sup has to be quicker than my best mates Scooby! 1-1.1 bar was enough to obliterate an evo 6 extreme on the roll with me mate Link to comment Share on other sites More sharing options...
merckx Posted May 7, 2006 Share Posted May 7, 2006 Nooooo! Must have more power! I wont rest until I'm making 1.2bar. My Sup has to be quicker than my best mates Scooby! The plugs you've got will be fine, but a 0.7mm gap is a little narrow. 0.8 to 0.9 would be better. Hadyn's right about the boost, it will go up when it gets colder. But I would still remove the restrictor ring to see if it does go up. The ideal situation would to be getting just over 1.0 bar with the restrictor in or out - (whatever it takes) - in the summer - warmer weather. Then get the extra by fitting a bleed valve or boost controller which would give you the ability to adjust it when needed as the weather gets colder so you can limit the boost to 1.2 bar. Link to comment Share on other sites More sharing options...
Conrad Posted May 7, 2006 Author Share Posted May 7, 2006 Will do, I'm gonna take the ring out tomorrow and see what happens. Wanted to get a boost controller anyway so looks like that's next on my shopping list. Link to comment Share on other sites More sharing options...
