merckx Posted May 6, 2006 Share Posted May 6, 2006 Hi Can anyone please confirm the position for fitting a bleed valve. I've done a search but I'm still not 100%. I'm thinking Hose 1. Hose 1 - the input to the VSV Hose 2 - the output of the VSV which goes to the wastegate actuator. Thanks Quote Link to comment Share on other sites More sharing options...
JohnA Posted May 6, 2006 Share Posted May 6, 2006 There are various ways to do it. The VSV could remain functional, or it could be disabled. Have you got a picture of the bleed valve? Quote Link to comment Share on other sites More sharing options...
merckx Posted May 6, 2006 Author Share Posted May 6, 2006 Yes, here it is. Quote Link to comment Share on other sites More sharing options...
jaymdee Posted May 6, 2006 Share Posted May 6, 2006 Mate, Hose 1 is the output from the VSV back into the intake. Putting it here will do nothing. You really need to put it between the turbo & the actuator (not shown in pic). This is short hose above the actuator. I suppose putting it in Hose 2 will be ok as the VSV shuts when Turbo 2 operates so this hose is pressurised, therefore bleeding air off will still reduce the pressure on the actuator. J Quote Link to comment Share on other sites More sharing options...
