Suprash Posted May 5, 2006 Share Posted May 5, 2006 How do I clean it Cant get the car anywhere as Im far to busy and I need to clean this, anyone know of any 'How to' or references on it, Im about to check mkiv.com, but any help or info would be good....... Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 5, 2006 Share Posted May 5, 2006 Take it off. Soak it in brake cleaner or Gunk or something equally evil. Wash it out and dry it. refit -Ian Quote Link to comment Share on other sites More sharing options...
Suprash Posted May 5, 2006 Author Share Posted May 5, 2006 Cool, sounds easy, now you just got to tell me where the hell it is Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 5, 2006 Share Posted May 5, 2006 I sort of already have with me FAQ entry It's in the FAQs section, technical FAQs, engine component locations. Two 12mm bolts and it's off. Er, at least off enough for you to take the two coolant hoses off the bottom of it. Then it's off. Providing you took off the wiring plug and the intake hose. Anyway it's easy Watch out for the flapper valve that sits either in the intake manifold or stuck to the idle control valve, depending on the mood it's in. Don't try and take the stepper motor off the housing. -Ian Quote Link to comment Share on other sites More sharing options...
Suprash Posted May 6, 2006 Author Share Posted May 6, 2006 I sort of already have with me FAQ entry It's in the FAQs section, technical FAQs, engine component locations. Two 12mm bolts and it's off. Er, at least off enough for you to take the two coolant hoses off the bottom of it. Then it's off. Providing you took off the wiring plug and the intake hose. Anyway it's easy Watch out for the flapper valve that sits either in the intake manifold or stuck to the idle control valve, depending on the mood it's in. Don't try and take the stepper motor off the housing. -Ian I was told its fiddly..............that doesnt sound too bad........ Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 6, 2006 Share Posted May 6, 2006 I found getting the little coolant pipes back on a pain in the arse, order the gasket from Toyota as well before doing it, mine was pretty *uggered. Quote Link to comment Share on other sites More sharing options...
Suprash Posted May 6, 2006 Author Share Posted May 6, 2006 I found getting the little coolant pipes back on a pain in the arse, order the gasket from Toyota as well before doing it, mine was pretty *uggered. Eh ? Gasket, no one said anything about a gasket............cool will do, gaskets should always be replaced as a rule of thumb.........shouldnt they, lol.... Quote Link to comment Share on other sites More sharing options...
RedM Posted May 10, 2006 Share Posted May 10, 2006 Is this Idle Control Valve the same as the AICV? Quote Link to comment Share on other sites More sharing options...
Suprash Posted May 12, 2006 Author Share Posted May 12, 2006 Is this Idle Control Valve the same as the AICV? AICV Quote Link to comment Share on other sites More sharing options...
sarjo Posted May 21, 2006 Share Posted May 21, 2006 Sorry to bring this up again, but I've recently done mine and I've still got a stalling problem (although it is now less frequent), so I am not sure if I've done it properly. I removed my icv housing and there was 'something' inside it. But there was also a diaphragm type 'thing' which came out. Ok, blonde but, which bit is the control valve and should I have given both parts a good clean? I'm guessing its the diaphragm part. I'm going to do it again one evening this week, weather permitting so any recommendations on which product is best to use to clean it? Failing that, what is the next check point to try to eliminate my stalling, remembering it only does it when slowing to approach junctions or when moving very, very slowly in traffic with either a hot or cold engine. Quote Link to comment Share on other sites More sharing options...
RedM Posted May 21, 2006 Share Posted May 21, 2006 How long did you leave it to soak for? Quote Link to comment Share on other sites More sharing options...
sarjo Posted May 21, 2006 Share Posted May 21, 2006 How long did you leave it to soak for? Not long enough obviously!! Didnt have enough cleaner to soak it thoroughly so kept turning it around for about three quarts of an hour. Will do it again in the week and leave it overnight me thinks Someone has said use gunk spray but wasnt sure about that. Quote Link to comment Share on other sites More sharing options...
Robert Posted May 21, 2006 Share Posted May 21, 2006 i never soaked mine, i just cleaned with with some brake cleaner and a cloth, until all the crap was gone. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 22, 2006 Share Posted May 22, 2006 If you get a stalling problem when you pull up at junctions I'd also check the narrowband O2 sensor's output, it might be buggered and you might be overfuelling because of it. -Ian Quote Link to comment Share on other sites More sharing options...
Suprash Posted May 22, 2006 Author Share Posted May 22, 2006 Sorry to bring this up again, but I've recently done mine and I've still got a stalling problem (although it is now less frequent), so I am not sure if I've done it properly. I removed my icv housing and there was 'something' inside it. But there was also a diaphragm type 'thing' which came out. Ok, blonde but, which bit is the control valve and should I have given both parts a good clean? I'm guessing its the diaphragm part. I'm going to do it again one evening this week, weather permitting so any recommendations on which product is best to use to clean it? Failing that, what is the next check point to try to eliminate my stalling, remembering it only does it when slowing to approach junctions or when moving very, very slowly in traffic with either a hot or cold engine. Are you rinning a MAF with a BOV, this can cause stalling also ........ Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 10, 2006 Share Posted June 10, 2006 Ash, Have you attempted this yet? You'll notice you don't have one of those, cos your VVTi Idle control is done in the throttle body, gotta whip mine off now Gaz. Quote Link to comment Share on other sites More sharing options...
Suprash Posted June 10, 2006 Author Share Posted June 10, 2006 Gaz, I didnt bother in the end, I found the problem to be a blown pipe, down at the front right hand side of the block, just a little forward from the PS resevoir and to the left hand side of it. But Im sure I noticed some difference on mine as opposed to what I was seeing in a pic, which was obviously an pre VVT-i lump But thanks Quote Link to comment Share on other sites More sharing options...
