Guest MarkTT Posted December 7, 2003 Share Posted December 7, 2003 Just out of interest! What is the TT supra capable of being tuned to? Without replacing the turbos or engine internals? Quote Link to comment Share on other sites More sharing options...
Wipeout Posted December 7, 2003 Share Posted December 7, 2003 Exhaust, De-cat and up the boost = 400 BHP ish. All for well under £1000 (depending on BLING factor of parts used) I'm sure someone will correct me if i'm wrong. Quote Link to comment Share on other sites More sharing options...
Guest MarkTT Posted December 8, 2003 Share Posted December 8, 2003 Yeah but what about with chipping, fuel pump,intake, upgraded IC etc.? Quote Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted December 8, 2003 Share Posted December 8, 2003 The skies the limit, well, your bank balance is really Well over 700 is not too difficult with the bits and pieces. Dont think Supras are the cars to "chip" though. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 8, 2003 Share Posted December 8, 2003 Originally posted by Patrick_Devlin The skies the limit, well, your bank balance is really Well over 700 is not too difficult with the bits and pieces. Dont think Supras are the cars to "chip" though. Chipping a supra normally involves removing fuel cut and increasing the boost which you can do alot cheaper and safer yourself. Quote Link to comment Share on other sites More sharing options...
eyefi Posted December 8, 2003 Share Posted December 8, 2003 stock turbo (style) limit is about 500 hp. an 18psi decatted supra is quite an effective street car. have a good search around. all the info's in here. Quote Link to comment Share on other sites More sharing options...
Wez Posted December 8, 2003 Share Posted December 8, 2003 Originally posted by eyefi stock turbo (style) limit is about 500 hp. I am guessing that is with hybrids. Quote Link to comment Share on other sites More sharing options...
Steve W2 Posted December 8, 2003 Share Posted December 8, 2003 Originally posted by Wipeout Exhaust, De-cat and up the boost = 400 BHP ish. All for well under £1000 (depending on BLING factor of parts used) I'm sure someone will correct me if i'm wrong. It should also be noted that thas a reliable 400 ponies just by taking the cats out, adding a £10 restrictor ring and FCD (J-spec). Quote Link to comment Share on other sites More sharing options...
Wipeout Posted December 8, 2003 Share Posted December 8, 2003 Originally posted by MarkTT Yeah but what about with chipping, fuel pump,intake, upgraded IC etc.? All fueling is good for 400 hp, you will need to remove the fuel cut as Wez said. A good condition IC will cope with 400 hp aswell. Stock intake?? Some say leave it and some say change it. I guess it's up to you. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted December 9, 2003 Share Posted December 9, 2003 Exhaust, De-cat and up the boost = 400 BHP ish. Optimistic for a J-spec with a std IC. My dyno figures for this were 360BHP. A decat will not increase power per-se, it will just allow the boost to increase and therefore increase power. You can get exactly the same figures with a boost controller and maintain total control of your boost. 400BHP is what I was told my engine produced ("no we haven't had it on a dyno/RR") but 360 was the actual figure. Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 9, 2003 Share Posted December 9, 2003 Well I got 393bhp at Well Lane @ 1.25bar Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted December 9, 2003 Share Posted December 9, 2003 393 - Impressive figure. When I got my car and talked to a few people in the know they all reckoned 360 was more likely than 400, but then again I don't use more than 1.1 bar on the road. Maybe the extra boost you're running accounts for it. I use 1.2 on track but with octane booster. Sounds like a visit to the RR is in order. Quote Link to comment Share on other sites More sharing options...
Steve W2 Posted December 9, 2003 Share Posted December 9, 2003 I am sure there are few other peeps running close to 400 ponies at that kind of turbo pressure. Quote Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted December 9, 2003 Share Posted December 9, 2003 367 rhhp at 1.2 bar (measured at THOR) Quote Link to comment Share on other sites More sharing options...
Steve W2 Posted December 9, 2003 Share Posted December 9, 2003 Originally posted by Patrick_Devlin 367 rhhp at 1.2 bar (measured at THOR) Patrick, what does that equate to at the crank? Are you auto or manual. 400 bhp with 20% transmission loss in 320 rwhp! COOL! Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 9, 2003 Share Posted December 9, 2003 Didn't we work out that crank power was ~11% higher than hub power for a manual? So ~407bhp? Quote Link to comment Share on other sites More sharing options...
Steve W2 Posted December 9, 2003 Share Posted December 9, 2003 Originally posted by Thorin Didn't we work out that crank power was ~11% higher than hub power for a manual? So ~407bhp? Sounds pretty good to me:) 407 ponies is very respectable indeedy. Quote Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted December 9, 2003 Share Posted December 9, 2003 I was quite happy with that figure Running lean as well at high boost, so once fuelling is sorted will hopefully see a few more gee-gees squeezed out!!! Quote Link to comment Share on other sites More sharing options...
Suprash Posted December 10, 2003 Share Posted December 10, 2003 I made 357 rhhp at Thor http://www.platinumrogue.pwp.blueyonder.co.uk/smilies/009.gif Quote Link to comment Share on other sites More sharing options...
