Standard Toyota Sub Box
Zed
As the title says, this is the optional sub box for Supras that had the optional 7 speaker sound package.
You'll notice the two bits that have been cut off, this was done by the previous owner in order to remove it without having to remove the boot release cables. It also makes fitting it easier, the box itself is perfect and the 4 mounting holes where the bolts go in are still in place so that it can be fitted securely.
This can be supplied with the standard speaker for £35 + p&p.
Or
With the speaker shown which is a focal item, for £80 +p&p.
I had it wired up via an Alpine 2 ch amp a picture of which has been included, let me know if you're interested in this.
I'm not sure what the standard speaker is like as I never used it like that, it's only a paper cone though. The Focal speaker is good though, it's just the right amount of bass to be noticed, but if you want to actually feel evrything vibrate then this won't do that.
I'm in Bradford, BD4 9LJ. :)
I think your best bet would be to buy it with the standard speaker, if you like it fine, if not, it would only be a £35 quid investment which would be fairly easy to get back as I'm sure someone would snap it up quickly. :)
